Help picking out an amplifier
Hadec
haha yeah they would, or if you save up a little a Crescendo 3k would make you very happy, i believe they are around 550. That Audiopipe will work fine tho aslong as you wired it up correctly.
Ill be sure to get it professionally wired by Perfect Soundz. What about a powerbass amp? Powerbass XA3000
Edited by Hadec
Working on my first car audio build ever!
Currently have:
- 1996 Lexus LS400 sedan
- Diablo Hellfire Proto Amplifier
- (2) 12" Fi Bl Subwoofers
- Vented subwoofer enclosure from Perfect Soundz
- Installed by Perfect Soundz
Needs:
- Battery: probably XS Power 12V 2400
- "The Big 3"
Doesn't look good, check this link out.
http://www.caraudio.com/forums/amplifiers/172580-official-powerbass-xa-3000-sucks-thread.html
It's gonna be tough to find a true 3k watt RMS amp for under 400$. Audiopipe is probably the cheapest I would buy. Unless you look around and can find a good deal on a used one.
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
Yeah I was looking at that one too. What about this one? http://www.sonicelectronix.com/item_32979_Hifonics-HFi3000D.html
Currently have:
Needs:
- "The Big 3"
That would suffice, just make sure you have the electrical to support it. May not get exactly 3k out of it but for your budget, it fits.
Old Setup
So how much does it cost to do the big 3?
Currently have:
Needs:
- "The Big 3"
Just gotta measure how much 0 gauge you need and buy terminals.
Old Setup
So I want an extra battery, big 3, and a capacitor?
Currently have:
Needs:
- "The Big 3"
Big 3, and probably 2 big batteries if you dont want to get an alternator. You will be running around 3k just to the subs so you are gonna need it. Figure out what your alternator can do and go from there. You're on the verge of needing a bigger one though.
Old Setup
is the subs your buying dual 1ohm or dual 2ohm ?
They can be either. You can choose on their website if you want 1 or 2 ohm.
Currently have:
Needs:
- "The Big 3"
  • Who's Online   0 Members, 0 Anonymous, 351 Guests (See full list)
