Alright im sitting here trying to crunch numbers and im having a hard time trying to figure the port, the over all inside dimentions are 32 1/4 high,,35 wide and X deep, i have a max of 40inchs deep, i want the port to be 4" wide and 32 1/4 high, if its smaller hight wise idc, i had the whole thing calculated but i just realized i forgot to take the false floor into sccount so ill get nack with numbers
I need to jave 12 cubes, and id like 30hz
tuning, also everthing is going to be double 3/4 aside from the inside port
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
the port height will be inner dimensions, so remember to take away the width of the wood on each side,
so if your wall is 32.25" tall and you have one peice of 3/4" for top an bottom(just for example)
take away that 1.5" and it gives you 30.75" port height.
Edit, just saw you said inside dimensions..either way hope this helps iv done too many draw ups and forgot to do this^ lol
Edited by RickyFriery97
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
I already took that into account hence i said inside dimentions
Lol thanks dude, i did that last night i was like fuckkkkk
iyea i just read over it quick, and i think you edited in the last part as i was typing lol
idk if you use torres or not but ill mess with that some and see if i can come up with anything
I do im just on my phone right now, and thanks, but in order to fit 2 15s across, i need 30" i have 35 max, and im porting drivers side
you're going to need more than 30. you have any idea how weak the middle part is going to be with next to nothing left.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Im doing a double baffle, some serious bracing, and seroius resin
Would pvc piping be noisy? I have a wall worked out to pretty much how i want it with, 4 4" ports eacch 7" long, 34.25x38x21 1/4 , doubled 3/4 all around, the math adds up to the calc, id just need to take the bracing into account then i should be good, im shooting for a daily monster with decent numbers
can you flare the pvc?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
