AUDIO-CONCEPTS UBL!!!
Well, I went out and did some work today, pillars arent installed, but they are painted, and tweeters mounted, just going to let them cure overnight, and get them in tomorrow afternoon!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
Well, everyone, I have good news!!! A-pillars are installed.......finished.......done!!!!! Bad news......still not finished with the install!
But here are the final install!
Next step is to finish the amp rack and trunk clean up, mounting of the alesis, and final tuning!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
Well on top of finishing my pillars, I thought of how I can mount the amps and dress up the trunk. So here was some progress!
Test fitting!
This just the base, which holds the fuses and amps. There will be a center section that will have decals of the equipment. All the sections will have lexan and LED's that will be activated by a hidden switch. The panel will be painted the same denim blue as everything else. Then I am going to make a beauty panel that will go from side to side, as well as a false floor to clean up the bottom of the trunk floor. Those panels will be covered in the same carpet as the trunk. I may also make side panels to make everything flow as one.
Tell me what you think!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
i love where this is going bro, the vintage Linear Power amps are so damn sexy! When is it going to be finished?
Follow my Tweet (Twitter)
thanks Steve, it means a lot getting recognition from you. I'm in the process of rebuilding the amp rack and rear beauty panels. I had a slight argument with my router and frustration took over. But this coming week I will be definately making some process. My goalis to have it done before April 15th. I have a local show I am going to try to attend, depending on whether or not I have to work. They will have an SQ and SPL division, so I may do both and see what needs to be done, to really finallize tuning and cleaning up everything, for final installation and enjoyment.
I'm not sure what bracket I will be in though, I used to be in SSNW, but that was with an SPL only car, this is my daily. I mean it's a single sub 1500 rms max power, so I don't expect to win, just want to see what it meters at, at full power.
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
  • Who's Online   1 Member, 0 Anonymous, 2080 Guests (See full list)
