is everything correct on this box. yes i realise its not including woofer displacement and bracing. how would i go about using all thread as bracing.boxspecs.png
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
oh i forgot to mention i could invert mount it if necessary
any one please
bump the sub needs 6-10 cubes at 33 hz.
i don't like that calcluator... :trippy:
from what i'm seeing there'es no account of any bracing displacement or sub displacement. also, you probably want a second baffle.
other than that the volume looks good.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
i'm unsure of how to calculate bracing displacement. but the sub is .22 so that leaves me with 6.3 cubes before bracing
i don't see a place to enter that in this calculator. have you tried torres calculator?
More box builds
i cant figure out how to recreate the port area in Torres since i'm getting different port area and tuning results
Edited by bass_stalker
How much power will you be running to the sub?
im planning on buying the dual 2 version. the diablo prototype will do 380 to 550watts at 4 ohm or it will do 1450 to 1920 watts at one ohm.
i am planning on running at 4 ohm until i can upgrade my electrical to run at 1 ohm
  • Who's Online   0 Members, 0 Anonymous, 1366 Guests (See full list)
