98 tahoe pass door problem?
let me make sure im reading this right
with the switch connected.
you hit lock and nothing happens? What happens if you lock it manually and hten hit lock?
what happens if you lock it manually and then hit unlock
What does the drivers door do at the same time.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Explain again please.when switch is diconnected you can lock unlock with the alarm? And when you connect the switch does it lock automatically without using alarm or switch
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I just asked you a bunch of questions answer them individually
what do you mean close. use the correct terms. lock or unlock. open and close is how you get in and out. it makes it easier to decipher what oyu are talking about.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
yes when disconnected it unlocks/ locks like mormal with the alrm control but the switch connected it doesnt lock or unlock
Grab the relays above the gas pedal that's were they are pretty sure its light blue dark blue wires ones lock the others unlock with neg pulse. Sounds to me he's grabbed the wrong wire wherever he grabbed them at.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
he should have never touched the passenger side by itself. He should have grabbed them at the relay or even at the door switch. Thats why I asked what the the drivers door did at the same time.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I'm sorry about that, and when the door switch is connected the door does not unlock/lock for some odd reason?
And like I said I have zero idea how it even works with the switch being disconnected. I dont think its possible.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1334 Guests (See full list)
