I highly doubt the distro is the issue, I would do a run of 0ga - and + to the rear batts pulling that much power,
are you running too low of an ohm load? I've seen a few RF amps have issues going below 1ohm. check your pre outs too
Can you post a pic of the front battery with the wires connected to it? I want to see the terminals and such...
i dont have a pic of that.. i got pissed and tore everything out right away. all it was, was a normal front to back battery setup. fuse was 18 inches away from front battery, and 18 inches away from back battery.. 0 guage ring terminals as connectors sotered on..
My youtube channel, please subscribe
http://www.youtube.com/ballinblaza
I dont see where your back cable is hooking to the front. If you connected it to that little dinky terminal that would be a big mistake........ If you hooked your wire up through the dist. box then it would have been a bigger mistake. Not doing the big three could have been very helpful as well......
that dinky terminal isnt actually that small, it worked great, and the big 3 has nothing to do with it, when my system did play at full tilt, i only dropped from 14v to like 13.5v at Idle
Edited by homiewes
i would have ran a run to the (-) from front to back but i ran outta wire. and at first i was running a 1ohm load, and i eventually wired it to 4 ohms and the problem still existed..
