jkiller Posted October 31, 2011 Report Posted October 31, 2011 can some one please help me i wanna run 2 6 inch earo ports but cant figure out the length they need to be to tune to 32 hz this is the last peace i need to finish up this box and put the top on it so it can be ready when the speakers get here box is 6.176 cubic feet before port displacment some one please help me
FiNaLaLmAsY Posted October 31, 2011 Report Posted October 31, 2011 Straight length port required=19.73in Flare length port required=20.73in from http://www.psp-inc.com/tools.html enjoy. 02 Nissan Sentra 4 DD 3500g 10's Crescendo Audio 3500 @ .5ohms Soundstream EGA4220 Fronts German Mestreo 6.5 Component Set 110Rms Rears RE XXX 6.5 Component Set 2ohms 220RMS 1 Dyralast Gold 1000Amp Battery 1 Vmax 2000amp Battery DC Power Inc 270XP Amp Alternator BIG 3 Upgraded All 1/0AWG Setup 8 1/0 Awg Runs
bassrace Posted October 31, 2011 Report Posted October 31, 2011 Well what's your box dimensions so I can give you an accurate number.? 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
jkiller Posted October 31, 2011 Author Report Posted October 31, 2011 thanks guys well i cant fit ports that long in my box i was thinking 3 4 inch ports at 13.15 inches straight would this be ok for the box thanks agin for yalls help
jkiller Posted October 31, 2011 Author Report Posted October 31, 2011 Well what's your box dimensions so I can give you an accurate number.? 19x42x19
bassrace Posted November 1, 2011 Report Posted November 1, 2011 Do you have alot of bracing? Or double baffle? B/c I get your right around 6.9 cuft net before port displacement. 2 6" aeros is too little of port area 3 4" is even less... You could go 1 10" ...? But it would be fairly long...or 5 or 6, 4" aeros... Let me know what suites you and I can give you some lengths. 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
412 CVX Posted November 1, 2011 Report Posted November 1, 2011 this is getting really complicated and messy and overall there's not nearly enough information to give you an accurate answer. i really think we need to start from scratch here. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
