Determining port area
herbykw
I'm building a box for Four DC lvl 2 8"s. The box design is 3.46 cubes. How do i determine how much port area is right for a single 8"? It was recommended to use two 6" ports. Using two 6" ports they have to be 31" long to tune it to apron 35 hertz. That ports the port area at 17531 cubic inches. Is this too much?
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
Need more than just the cubes to get that. IIRC my old box with my 4 - DC 8" was 34"x14"x18" before port. And I had a 3" wide slot port 12.5" tall tuned to 33htz and it got down and dirty. 141.9 on music with a SAZ-1500D.
your 2 - 6" ports are 56.54 inches of port / 3.46 = 16.3" of port per cube. some say thats fine but I like about 12" of port per cube. mine was close to 12" of port per cube.
have you tried to use the torres box calc. once you figure it out its really simple. I have spoken to rusty regarding those subs and he said keep them in about .8 cubes net. Im actually going back with 2 - 8" DC in a box thats about 2cubes before bracing and 45's. so I will be around .9 cubes.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
Two 6" port is too much for that box. If anything, i would do one 6" instead.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Thanks, how did you determine this? I have used torres calc, but that doesnt help with what im asking, unless im just missing it.
ok, why? how do you determine that?
06 300C 5.7 Hemi
K&N CAI
DC Audio 3.5k
6 DC Audio 8"s
I used Autocad. I drew a 6" circle and then did did a properties of it and it gives me the area. and then I multiplied it by 2 for two ports and then divided it by your box volume. odd information about circles. whenever you double the size of a circle say 2" dia to a 4" dia you have 4 times the area.
So 1 - 4" circle is the same as 4 - 2" circles
Area of a 2" circle is 3.1416
Area of a 4" circle is 12.5664
PPI dbl din
DC Level 3
DC audio 2.0k
If using an aeroport, a single 6" port is fine. Go with more port area and you're looking at having to mod your ports. Are you totally against using a slot port?
IM not against using slot ports at all. If i use slot ports the same question is there. How do i know how much is enough, but not too much port area? I dont want someone to tell me how much to use, i want to know how to determine it myself, for future builds.
06 300C 5.7 Hemi
K&N CAI
DC Audio 3.5k
6 DC Audio 8"s
  • Who's Online   0 Members, 0 Anonymous, 1788 Guests (See full list)
