Seems pretty simple to do, About to go out to the garage and grab it and take it apart haha.
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
http://www.hondacivi...ix-*56k*-75438/ here you go man. Good luck. Seems like it would be easy to do.
good luck hope it helps. Hopefully you aint the type that can take a remote apart and almost put it back together. Haha
Edited by vettedude102
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Well I took it apart and searched it for about 45mins trying to find that fuse or w/e it is with now luck, If you look at the thread again the last post the person has the same one as me and had no luck finding it ether. but I looked on the back of the board and found a thing that says RCAGND so I flipped it over and theres a thing that says P301 but theres nothing there. I also was wondering what this thing was so I did some searching and it looks to be some type of fuse so this could be the problem?
http://www.konkurel.ru/raychem/PolySwitchF/RXEFpdf/RXEF075.pdf
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
Did anything on the board possibly start with fu?
Your link could also be what is wrong with it. I love pioneer decks but this is why they suck.
2003 corvette z06
Nope not 1 thing that started with "fu" I guess we will see if the new deck solves the problem...
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
Sorry man, I'm trying to do some searchin. Hopefully the new deck fixes it. I'll keep lookin if I find anything I'll let ya know.
2003 corvette z06
If the new deck dosnt fix it add more grounds to the rear battery bank. That was my issue and I run the best Kenwood excelon non TV deck and have 2 runs of pos and 2 runs of negative to my rear bank. I also did the big 3 and my front battery is grounded to both alternators but I ended up adding 2 frame grounds to my rear battery bank too and it got rid of the rumble problem. I never had a thump issue but had a rumble problem bad when I was running 4 Audiopipe 3000s it was so bad I had to take out two until I realized what it was. I have since sold everything Audiopipe and now run a DC 7.5k but add 2 frame grounds to your rear battery bank. Should take care of the rumble at least
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
i kind of have the same issue but im sure its just the amp dis charging it only does it when i disconnect my rcas from the amp. I called rockford fosgate on this issue seen its a 1500 bdcp they told me it was normal because the caps wer still charging and discharging not 100% sure if this is your issue but thats what they told me. i may be wrong and if i am please do tell the solution. i have checked my grounds to my rear batt bank and all 3 1/0 cables have 0.0 ohm for resistance so i dont think its my grounds.
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
  • Who's Online   0 Members, 0 Anonymous, 4742 Guests (See full list)
