xs power d3100??
okay guys, im new into car audio and i need help. im running two 12's with a kenwood xs-1s @600w rms. i want to get some component speakers and that new small SD250.2 amp for the speakers. how do i wire two amps to the batt, and should i just get a xs power d3100 for both amp instead or continue using my regular stock car batt??
Do you plan on ever running more power? I do not see the point of running a D3100 if that is all you will be doing...
well if you plan on upgrading to something bigger in the future a d3100 would be a good way to go. but if you don't foresee that happening in the near future, the D3100 would be a little overkill. there's nothing wrong with electrical overkill, but if you're running less than 1k there's really no need to spend all the extra money. a smaller XS battery or maybe a yellowtop (correct me if i'm wrong) would probably suffice.
the easiest way to hook up 2 amps involves using a distribution block. basically you'd take a run of 1/0 awg wire hooked to the battery (don't forget to fuse it!) like you're only using one amp. connect the other end of the wire into the 1/0 input on the dist block, and from the dist block 4 awg outputs run 4 awg wire to the amps. same thing applies to the ground, 4 awg from amps to dist block, 1/0 from dist block to grounding point.
More box builds
I'm with captain stupid.
thank you for ya help
  • Who's Online   0 Members, 0 Anonymous, 1024 Guests (See full list)
