Since I'm goin for soth i guess i should update this,
Purchased some nice Kenwood 6 1/2 components for the front doors!
Also purchased a Solid Audio F2500D.
Running it at 2 ohms so somewhere between 1-1.5k watts
Pics of the Solid audio amp tm
06 Jeep Grand Cherokee
2 DC Level4 12"
Soundstream TA1.3000d
4 RF Punch 6.5" Components
2 RF Punch 3.5" 2-ways
RF Prime 400.4D
XS Power XP950 +&-run of XScorpion 1/0 OFC My Civic Build
  • 3 months later...
super delay but finally got my laptop functional (had a full beer filter through the keyboard lol) so ill update this
started off by running the new power and ground wire and adding my new xp750
old 4ga vs new xskorpion 1/0 ofc
did some digging and couldnt have found a more perfect hole in the firewall hiding right behind/under my battery!
crimped and soldered
cable management. also lucked out seeing as this was able to fit (barely) under the trim that runs along the side of the car
rough and messy wire up but it was a lot of progress for the day so i was happy
now for the new box to accommodate the second 12 i aquired
started off on the double baffle
next on some of the angled port walls. didnt turn out as well as i wanted it to but it is still functional.
EDIT;; also forgot I ran out of birch so instead of wasting 20 bones on a 4x4 sheet i used some scrap mdf i had lying around. since it was only for the internal port wall and will never really be seen i wasnt too concerned.
got the box started and placing the port. also painted all the visual parts of the port blue for later
port and top piece secured
Edited by KickerKid58
2 DC Level4 12"
RF Prime 400.4D
internal bracing with a 1 1/2" dowel rod. Cuts werent perfect either, but i went heavy on the glue and used #12 2" screws to secure them
Baffle cut out and mounted
subs in and looking sexy
So its been roughly 4 months since then. ripped the box out the other day to give the baffle a face lift
popped out the level 4 12's
after applying some wood filler
some good sanding, more wood filler along with more sanding. touched up the port and gave the baffle 4 coats of a nice gloss black
added a decal i had laying around
flash really shows the gloss
2 DC Level4 12"
RF Prime 400.4D
Box looks great. Did you use primer? I noticed that with wood if you don't use a good primer you still see the texture of the wood. Tuned in.
I didn't use primer and am a lil annoyed i didn't. At certain angles with the light the texture does show pretty clearly. I'm not too concerned tho still turned out pretty good.
I'll shoot um some pics of the car tonight or tm.
Dropping the car off tm to get the whole drivers side fixed up while im on the beach in florida haha. finally putting the body work over the bass lol
2 DC Level4 12"
RF Prime 400.4D
once im back from vaca im planning on using some thin plywood or thick cardboard with a roll or two of gorilla tape and try to seal the trunk off
2 DC Level4 12"
RF Prime 400.4D
