Ross's "in-between" build. (Now with 4th order. Page 5.)
Granted not great for meters, but.... from 8 10s slot ported @ 42Hz, 1780 watts, 8 volts input, 151.1dB, to a single 12 in a t-line @ 39Hz, 1100 watts, 4 volts input, and a 148.3dB, I'm pretty happy. However, my SQ is much better. Now, I'm using a single 8, in a t-line, 600 watts, 140dB, and so far the best SQ by far.
wtf does it matter what your input voltage is you newb..
Fritos im just letting you know that he isn't a newb...He is very knowledgeable about audio bro and is very skilled when it comes to building and tuning audio setups... Just and Fyi and Input voltage DOES matter :)
not so much when your posting clamped power though.
Welp thanks to my lovin girlfriend holding my flash light and braving the cold I got my processor in. So I got it a little better where it Doesnt bottom out. I need suggestions on where to set my xover frequnecys, subsonic and another frequency on the processor. The tline is tuned at 24hZ so may somewhere around there? Also since I have this sub wired at 1ohn before rise would that be a reason for it to bottom out because the kicker amp is only 2 ohm stable?
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
Put the REX8D4 in today and it sounded better but still not like it should be.. I have plans to build another T-line and forthorder and another T-line for my freind this weekend.. It will be a long night. lol I got a video but it didn't pick anything up. I actually have backwindow flex off this little woofer. lol
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
Dude you suck at building boxes....
Seriously though man.....I cant get over how far you have come in such a short period of time, it's always exciting to see what you're gonna be doing next!! Keep it up my hillbilly friend!
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
Thank you my freind. I can't seem to design them but I sure love building them. You need to get off here and get your amp rack done so I can see some updates! There will be lots of pictures this weekend. My freinds building me a metal stencil of the the panda I can brand in all my boxs from now on. lol
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
The enjoi panda or a different design? Either way it'll be pretty cool I bet!
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
I got a belt buckle of that. lol It will be the normal enjoi panda like my avi. Not the humpin ones.. Or playing "leap frog" as I used to tell the principal when I got in trouble for wearing it in Highschool. lol
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
I think when you make a 4th order for it you will be much happier. Its a sub that moves a whole hell of alot easy! If your gana build another t-line id try the little loading walls. If you build a ported or 4th order make it on the small side, other wise they bottom out easy.
Are you talking about the epic 8? I hope it will sound better man. The design I have been told to use is .75 on the sealed side and 1.85 on the ported side tuned to 55hz. Does this sound good? Also what do you mean by smaller loading walls? Like less port area? Thanks for the advice man!
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
Yeah im talkin bout the epic 8.
As for when i said the "little loading walls" i was talking about the pictures someone posted up and he had the 3in loading walls.
As for your 4th order im not the best with those but if i was building it id do .5 sealed and 1.0 ported tuned to 49hz
