Put the Phillips head screwdriver on the screws, And hit the screw driver down so it bites the screw. ( Not super hard though. ) And push down on the screw driver when backing the screws out. That way you don't strip the screws, and then your fugged. I had to do this on a 18 XL. Fairly easy.
Do this and get all the bolts out then hit the basket itself with the hammer upwards.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
I wouldn't hit the basket with a hammer take a flat head and the hammer and use it as a chisel to break the glue seal between basket and motor
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
I didn't have to hit mine and it came right off. Glue must of broke on mine. But i would wrap the hammer in a rag or something, so you don't chip or damage the basket. Unless you have a rubber hammer.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Yeah this would seem more effective....
Its All Good!!!
Build on hold...
I'm going to go purchase a rubber hammer tomorrow...ima b getting the sub reconed from a 15 to an 18.....that's the reason for removing the basket
Its All Good!!!
Build on hold...
Well I always used a hammer with no problem.(all the ones I've done have been stuck together tight). Your not hitting with all your might you just give it a good tap, but yea a rubber mallet would be the best thing if you were worried about damaging it.
And using the screwdriver to break the glue between the motor and basket did'nt turn out too well when I tried last if you slip you'll scratch the top plate.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Oh yeah that's a good point I don't want to scratch the Shit out of my top plate....Aight ima just try to hit it with a rubber hammer
Its All Good!!!
Build on hold...
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
