enemyofsilence Posted November 7, 2011 Report Posted November 7, 2011 ^^^ Ive heard/read that vw (golf/jetta) are known for their engine bays getting hot and that having an aftermarket intake wont help... and even with a cold air intake, once the air reaches the turbo it heats up again?? Can anyone elaborate on this?? I am curious to install an aftermarket intake on my 1.8T jetta but if it wont help with performance/sound, then i duuno if its worth the trouble..... Team Bass-Hz
BlackWhizz Posted November 9, 2011 Author Report Posted November 9, 2011 An aftermarket intake will increase the sound of the turbo just because you take of that big ass black intake housing. But if I were you and I had a tdi i wouldn't give a shot about that Whistle! Throw a sick ass 4" exhaust and a cold air intake to begin with (take out that cat and muffler if allowed in your state) then find a company that makes a nice chip or module for your car, that is the cheapest and fastest way to add horsepower on diesels! Later on down the road you'll want a bigger turbo, injectors and a nice fuel pump. Thanks! To bad i live in holland. That smoke of your truck looks nice. In Holland we have to pass emissions and many other points (rust/brakes/basically the entire car). Because of that i have to install a cat or make someting interchangeable to pass the emissions test. I have looked around but i have to do chiptuning because u can use a powerbox in VW diesels but well... that tricks the computer to pump more diesel (it triggers the ECU that the engine has to warm up) in the engine. That way it produces lots of black smoke when u are at high rpms.
Guest Posted November 9, 2011 Report Posted November 9, 2011 too bad you guys dont realize eclipsechris has worked as a mechanic for like 5 years.
01VWGREENMACHINE Posted November 9, 2011 Report Posted November 9, 2011 ^^^ Ive heard/read that vw (golf/jetta) are known for their engine bays getting hot and that having an aftermarket intake wont help... and even with a cold air intake, once the air reaches the turbo it heats up again?? Can anyone elaborate on this?? I am curious to install an aftermarket intake on my 1.8T jetta but if it wont help with performance/sound, then i duuno if its worth the trouble..... i can tell you for a fact dyno tested it improved my sound and my hp and i have engine code AWW with my 1.8t http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
white4d96 Posted November 10, 2011 Report Posted November 10, 2011 Smoke =/= power, contrary to popular belief. Smoke means an inefficient burn and wasted fuel. That being said, a TDI with an exhaust sounds sicker than sick. Too many projects, too little time...
