Well I thought for aero ports you need 9-13 squared of port per foot? Only reason why I went with three 4" instead of one lol
Edited by fmedina
I don't know where the idea of X in^2 per ft^3 started but it is not a very good ideology to follow. If that were the case a single port for a single 12" driver in 3 ft^3 would be 36 in^2 for 12 in^2 per 1 ft^3 which is a 3x12" port...and good luck fitting it inside the enclosure due to the port length required. That's a huge port for a single 12"! Most drivers out there can't excite that huge port area, so that huge port is wasted for the most part.
As I mentioned in my last post I would ditch the third port because you don't need it / will never be able to utilize that much port area with the power you are using. In my testing with a single OA 15" I saw an increase of 1.2 dB going from a single 6" aero port to a single 8" aero port...but only while using a clamped 2700 watts. With 1500 watts there was almost zero gain (IIRC it was 0.2 dB).
Electrodynamic
Power handling is not a power requirement! Don't install suckage!
Simon Eichenberger is the man.
My PM's are disabled.
interesting thank for clearing that up. ive been messing around and ima see how a single 6" looks. that what i have now but i kinda screwed up so i wanna do it properly this time.
A single 6" will do very well. That's what I used in my daily setup with a single Obsidian 15" in 3.5 ft^3. :)
Electrodynamic
sweet so hows this? will it matter if the motor is close to the port like i have it in my design? or will it not make a difference.
Much better. :) I would put the port off to one side and not in the middle of the box. That way the port isn't obstructed by anything like a big motor. ;)
Electrodynamic
haha for sure thanks man :)
where the fuuu did you get the model of that subwoofer?
I use Google sketchup. Downloaded from their gallery lol
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
