voltage when at full tilt
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
you have a bad ground or your voltage is dropping too low and your amp is going into protect mode.
More box builds
I'm with captain stupid.
It's 1/0 guage n honesty I forgot to chek voltage so should I chek the ground
yes check grounds, but what does your electrical consist of?
HMU!!!
95 Bonneville SSE
get a multimeter and set it to DC volts. measure battery when playing music.
does the amp cut out when you're idling? or when driving?
how did you redo your ground. did you sand all the paint off where the lug makes contact with the metal? where did you bolt the lug to?
dont use the hifonics bass knob. its just bassboost and thats not helping out your case whatsoever.
how high is the gain knob on the amp itself? what about the bassboost knob?
answer all these questions and we'll be able to help you further.
Okay yes at idle n while driving
I got d grounds of the frame from d seats wich I took out n grinded d paint off
N I'm not shuts Wer to get the nob so for now I'm using hifonics nob
On the gain on amp is half way.. n d nob is 3/4 up n wen turn my volume up I have to put it half way as well
  • Who's Online   1 Member, 0 Anonymous, 1010 Guests (See full list)
