Lucky4Designs Posted November 8, 2011 Report Posted November 8, 2011 Here's the pickle, I'm about to order one of the Sundown Audio SA-8D2's for my 1996 GMC Sierra ext. cab but before I do so, I have a two questions that I figure I would get a complete answer from the guys at the SMD Forums! Question #1: I am wanting to place the sub face out underneath the rear bench seat on the driver's side. Sundown calls for an enclosure that's between 0.6 and 1 cube tuned @ 30 - 40hz. I did read on another forum a guy had tested a few different enclosures and found that the SA-8D2 had the highest SPL in a box that was 0.8cft @ 34hz... Now to incorporate those specs into an under-seat build! Problem is, the bottom of the bench seat itself is slanted therefore cutting down on some internal volume of the box and the bump in the center for the driveshaft also poses a small problem for box volume. On the opposite side, I have the small box for the tire changing tools and I'd like to still be able to access that as well. Has anyone built a box like this before that could give me some pointers? I'm also a little confused as to how to go about adding up all the angles to get correct internal volume... Question #2: I am having trouble on finding an entry point in the firewall to run my power wire. I plan on running 4ga wire, but I don't know where I should drill in the event that I hit something important like a brake booster or something else that would cost me more money I don't have! If someone could answer these questions for me it would be a great help, I will post pictures of the build as I go with some shout-outs as well! 2001 Toyota Corolla CE: 4x Crescendo PWX6.5's 2x Crescendo FT1-SE's 1x DC Audio lvl 2 M1 8 (looking for more) Slot port box 0.7ft^3 @ 31.77hz Rockford Fosgate R750.1 1/0 Knu wiring all around Looking for XS Power D1200
Lucky4Designs Posted November 10, 2011 Author Report Posted November 10, 2011 I came up with a design for the box and it is exactly how I planned on doing it. I came out with 0.82 cft^3 @ 34hz. My only problem now is where to run my power wire? Thanks guys! 2001 Toyota Corolla CE: 4x Crescendo PWX6.5's 2x Crescendo FT1-SE's 1x DC Audio lvl 2 M1 8 (looking for more) Slot port box 0.7ft^3 @ 31.77hz Rockford Fosgate R750.1 1/0 Knu wiring all around Looking for XS Power D1200
will77530 Posted November 10, 2011 Report Posted November 10, 2011 i have a 98 silveradoo i just drilled a whole in the fire wall and put a rubber grommet around it. worked for me.
Lucky4Designs Posted November 11, 2011 Author Report Posted November 11, 2011 Where at did you drill? I was looking more to the left side seeing there's more space but the A/C lines are also over there and I really don't want to punch a hole in something. Lol 2001 Toyota Corolla CE: 4x Crescendo PWX6.5's 2x Crescendo FT1-SE's 1x DC Audio lvl 2 M1 8 (looking for more) Slot port box 0.7ft^3 @ 31.77hz Rockford Fosgate R750.1 1/0 Knu wiring all around Looking for XS Power D1200
Twostrokeking Posted November 18, 2011 Report Posted November 18, 2011 And pics of te box? My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Lucky4Designs Posted November 18, 2011 Author Report Posted November 18, 2011 And pics of te box? I came up with the idea last night to build a box on top of the back seat (since nobody sits back there anyway!) that will rest behind the driver seat. I'll still have the passenger side and the middle though. To cover the open area below the seat, I'm going to attach a panel to the bottom of the box to make it look like the baffle extends down to the floor. That's where my amp will be mounted and since my ground wire is secured underneath the rear bench seat behind the carpet to the back of the cab, it will allow me to drill through the piece of the baffle and run the ground wire through it, giving it a clean look. I'll end up carpeting it the same color as my interior and finding some means of locking the sub in place or building a false wall. I'll also bolt and weld the box to the bottom of the floor as a theft deterrent if they can manage to see through tinted windows 2001 Toyota Corolla CE: 4x Crescendo PWX6.5's 2x Crescendo FT1-SE's 1x DC Audio lvl 2 M1 8 (looking for more) Slot port box 0.7ft^3 @ 31.77hz Rockford Fosgate R750.1 1/0 Knu wiring all around Looking for XS Power D1200
