Chevrolet Silverado 1500
Audiobahnaholic
I'm getting ready to do a door speaker install on a guy's Chevy Silverado. I've got everything I need except one answer. Which wires are positive to the speakers and which are negative. I haven't looked to see the colors yet but, when I pop the stock speaker out and unplug it which wire do I run to the positive of the aftermarket and which to the negative?
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
easy way to test. take any 1.5 volt battery(A,AA,AAA,C,D,etc.. NOT 9 volt) and attach a speaker wire to each end, at the "terminals". Then touch those speaker wires to thepositive and negative inputs on the speaker, or clip. If the speaker moves out, like away from the magnet, then you have positive speaker terminal touching positive battery terminal. If not its backwards. The just look at which terminal plugs into what wire on the factory clip.
Hope that helps!
-Joey
play Moola.com its actually fun and free...
click here to join Money games!
its just games with free money!
Anyone else? Someone has had to do an install on one of these trucks.
I actually have, lol but have always just been running new speaker wires to amps. Well if ya get no answers trust me that way is VERY easy
Alright thank you. I will try it if nobody has another answer.
What my database says:
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 4" x 6" Side Pillar
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Just run new speaker wire to the headunit if your not installing an amp sounds like a lot of work but it is very easy to do then your sure whats what.
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Thanks a ton Roscoe.
  • Who's Online   1 Member, 0 Anonymous, 1122 Guests (See full list)
