snoop3111 Posted November 13, 2011 Report Posted November 13, 2011 Im looking for a good amp to power 2 Kicker L7 dual 2ohm woofers.I dont have the money or electrical system to wire to .5 ohm. The BB2400.1 is rated at 1600W X 1 @2ohm RMS. I just need something that puts out 1400-1600w true RMS at 2ohms for around 250. Quote
Guest Posted November 13, 2011 Report Posted November 13, 2011 i have a bb2400 thats been sitting under my bed for a couple months. worked fine when i hooked up a 4 ohm speaker to it. pm me if interested. Quote
amontoya2 Posted November 14, 2011 Report Posted November 14, 2011 Im looking for a good amp to power 2 Kicker L7 dual 2ohm woofers.I dont have the money or electrical system to wire to .5 ohm. The BB2400.1 is rated at 1600W X 1 @2ohm RMS. I just need something that puts out 1400-1600w true RMS at 2ohms for around 250. i have a hifonics brutus 1700.1 pm me if interested Quote
Lbox88 Posted November 14, 2011 Report Posted November 14, 2011 http://www.audiosavings.com/products/Mono-Car-Amplifier/PLANET-AUDIO-RXD2400-3000-WATT-MONO-CAR-AMPLIFIER-AMP/RXD2400+RB.aspx Quote UBL | Build Log
Scrubbalo Posted November 15, 2011 Report Posted November 15, 2011 Im looking for a good amp to power 2 Kicker L7 dual 2ohm woofers.I dont have the money or electrical system to wire to .5 ohm. The BB2400.1 is rated at 1600W X 1 @2ohm RMS. I just need something that puts out 1400-1600w true RMS at 2ohms for around 250. I have 4 BB1250.1 SPECS MonoBlock CLASS D Amplifier Max Power (2 Ohms): 1000W X 1 Max Power (1 Ohm): 1250W X 1 RMS Power (4 Ohms): 450W X 1 RMS Power (2 Ohms): 700W X 1 Signal-to-Noise Ratio: 102dB Frequency Response: 20Hz-250Hz Dimensions: 6-1/2" W x 2" H x 18-1/4" L 150.00ea Quote Sundown SAZ-3000 2 12" T3 DVC1ohm subs 58hz peak cabin frequency no deadner yet box tuned to 38hz BIG 3 upgrade yamaha patio speakers rear fill Alpine 9833 deck PPI FRX-456 Crossover PPI PAR-245 Preamp/EQ PPI DEQ-30 Band EQ fronts PPI tweets in kick panel PPI 2-way's in kicks for now 0/GA 1 run front to back Memphis 4 channel running rear speakers 75 X 4 only 2 channels used for now Planet Audio 4 channel 75 X 4 running front speakers 146.7 db usaci drivers door open 163.3 db port challenge mic in port 2012 4door silverado
snoop3111 Posted November 22, 2011 Author Report Posted November 22, 2011 http://www.audiosavings.com/products/Mono-Car-Amplifier/PLANET-AUDIO-RXD2400-3000-WATT-MONO-CAR-AMPLIFIER-AMP/RXD2400+RB.aspx I heard that the RDX series does not put out as much RMS power as the BB series Quote
