i have a 2011 chevy silvarado extended cab and wonna do a sub setup under the back seat. I have about 1.42 gross my main question is do i do sub up port to the side or two downfire sealed or somthing different id rather not fire the subs foward but if its the best way i will. Any input would be great if i do the downfire sealed it will be .71 perside so probbly do 10s if i do one sub up ported it will probbly be a 12 unless you guys think i should do somthing different will be doing about a 1k watt single sub or two 500 watt dual subs let me know any input or possiblites thanks!
"SilveradoGoesBang"
http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/
2 FI BTL 18's
CT Sounds 7k
2013 MidwestSPL Finals Xtreme 3 - 1st Place
ps also had somone tell me that three 8s in a downfire box sealed with all 3 subs on one side any input on that would be good also
"SilveradoGoesBang"
2 FI BTL 18's
CT Sounds 7k
Sundown sa-8s if you have 1.4 cubes after displacement .7 per sub would be great and theyre awesome monster 8s. I put 2 in a friends ext cab chevy subs forward port driver side with .8 cubes each on a kicker 1000 they sound great
Edit:spelling
Edited by lifted_silverado
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
Edit:spelling
Did u do both subs on the same side or one on each side?
"SilveradoGoesBang"
2 FI BTL 18's
CT Sounds 7k
  • Who's Online   0 Members, 0 Anonymous, 3192 Guests (See full list)
