Posted (edited)
ive been messing around in torres and i just cant seem to get it right. could someone help design me a box? i want around 3.5 net and tuned to about 30 with 2 common port walls. my max dimensions are 35W x 14H x 30D. its for 2 skar audio 12s. also how do you seal off the trunk? what do you use to actually seal it? or just anytips on how to do it. thanks :drink40:
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
now that ive been thinking about it would there be a noticeable difference between sealing them off from the trunk or just have them facing back with the trunk deadened? idk where i heard this but do you lose sq from them facing right into the cabin? im not gonna compete so numbers arnt important.
also most likely they are gonna be on 1700 rms
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
Posted (edited)
Some People use gorilla tape and great stuff for a cheap and easy seal. Or you could do it with wood, which of course will be more difficult.
As far as the box goes, why not go with a single port? I'm not saying go with one, just curious why 2 instead of a common port.
Edit: reread, you say 2 common port walls, so what you mean is you want a single L shaped port?
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
I'll try it to. I'm trying to learn! Then I can compare fmedina
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
This is what i got man, please, someone double check this!
My Truck Build
