SnowDrifter Posted November 16, 2011 Report Posted November 16, 2011 Could someone please explain to me how say... 1% harmonic distortion effects a sine wave? I know what THD is and that a lower amount is better - but not really the meaning of what percent it is. And also: Does anyone know how I can produce a clipped sine wave of X% THD so I can hear what it sounds like? Thanks! ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Wicks Posted November 16, 2011 Report Posted November 16, 2011 Could someone please explain to me how say... 1% harmonic distortion effects a sine wave? I know what THD is and that a lower amount is better - but not really the meaning of what percent it is. And also: Does anyone know how I can produce a clipped sine wave of X% THD so I can hear what it sounds like? Thanks! It's hard to find a simple explanation but here goes: http://en.wikipedia.org/wiki/Total_harmonic_distortion THD is the ratio of the sum of the powers of the harmonic components compared to the power of the primary frequency. Basically as you get distortion, harmonic components of the primary frequency are introduced. If you're playing 40Hz, its harmonic components would be 80Hz(2x), 120Hz(3x), 160Hz(4x)... which would be incorporated into the original 40Hz. Those higher frequency components would make the original sine wave look "fuzzy". As you compare the ratio of the distortion components to the original, you look for 1% as that is considered barely audible. If your primary 40Hz tone is 2W, then the distortion components would add up to 0.02W. 1% = 0.02W/2W I believe the SMD DD-1 looks for 1% distortion (when the light turns on). So without an o-scope and some complex calculations, the easiest way would be to buy a DD-1 and turn your gains up until the distortion light lights and then listen to the difference as you turn it back down. It would probably be more noticeable using the 1kHz setting as 1% distortion at 40Hz is probably not audible as low frequency distortion is harder to perceive then at higher frequency's. Make sense... This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SnowDrifter Posted November 17, 2011 Author Report Posted November 17, 2011 Could someone please explain to me how say... 1% harmonic distortion effects a sine wave? I know what THD is and that a lower amount is better - but not really the meaning of what percent it is. And also: Does anyone know how I can produce a clipped sine wave of X% THD so I can hear what it sounds like? Thanks! It's hard to find a simple explanation but here goes: http://en.wikipedia.org/wiki/Total_harmonic_distortion THD is the ratio of the sum of the powers of the harmonic components compared to the power of the primary frequency. Basically as you get distortion, harmonic components of the primary frequency are introduced. If you're playing 40Hz, its harmonic components would be 80Hz(2x), 120Hz(3x), 160Hz(4x)... which would be incorporated into the original 40Hz. Those higher frequency components would make the original sine wave look "fuzzy". As you compare the ratio of the distortion components to the original, you look for 1% as that is considered barely audible. If your primary 40Hz tone is 2W, then the distortion components would add up to 0.02W. 1% = 0.02W/2W I believe the SMD DD-1 looks for 1% distortion (when the light turns on). So without an o-scope and some complex calculations, the easiest way would be to buy a DD-1 and turn your gains up until the distortion light lights and then listen to the difference as you turn it back down. It would probably be more noticeable using the 1kHz setting as 1% distortion at 40Hz is probably not audible as low frequency distortion is harder to perceive then at higher frequency's. Make sense... Perfect sense! Thanks! ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
