getting 2 12s, i dont know which ones yet but all options are rated at 2k rms each. and all are kinda the same specs at..
QT.S= .544
VA.S= .779FT^3
F.S= 35.66HZ
Le= 3.29 mH
X.MAX= 26mm
QM.S= 3.112
QE.S= .659
do know i want aero port again, 8"-12" ? ... tune to 34hz, leaning towards facing foward again cuss i hate trunk rattle. but dont mind doing different port sub placement.
03 impala, 2 12s, 2 sundown 3ks. .
any suggestions are appreciated, do want people who have work with trunks ?
different subs require different space specs, can't really just throw any size box out there without knowing the sub, that would help a lot. DC XL require a different box than FI BL, just depends
Edited by miniSPLlancer
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
i know, those specs are exact specs of the sub then.
name of sub. franken hybrid monster moves up and down sub.
rated at 2k rms each. specs are..
QT.S: .544
VA.S: .779FT^3
F.S: 35.66HZ
Le: 3.29 mH
QM.S: 3.112
QE.S: .659
S.P.L: 83.85
B.L: 20.9
can you help.?
Edited by __d_a_v_i_d__
Well you have plenty of power from amps, hoPefully you have the electrical to back it up, if so, instead of guessing on a box size, like I have, there's a couple of ways you can go about this.
If you're looking just for a daily pounding setup, build it around 2.2-2.5ft3 per sub
If you're looking for it to meter well, ie competition, then start the box at 5ft3 and add wood to it until you find what size of box the subs like.
Tuning to 34hz will definitely be a low hitter.
Remember, if you build a box that is too big, you can always cut it down, especially since you're going with aero ports.
The sad part is, every car is different and subs sound different in different sizes. But I would start at 5ft3 and go from there. Good luck with the build man
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
Yeah I already ran the 6k before, only dropped to 13.6 full tilt. And I only metered my 2 10" subs with 1 3k, box was tune to 34hz, 6" aero. Doing 144s daily . . So want to keep everything on a larger extend..
Ofcourse I want lows, and loud . So sticking to that, doubt I'll ever tune any of my boxes pass 37.
I have a box right now, kerf 2.5 cubes per, tune to 30 hz. Imma try that first to break them in,
We'll see what happens ....
Anyone else ?
I'm hitting 147.9 ( Daily Setup ) with my (2) 12" Lanzar OptiDrive 1232s - (2) DB Drive DBA1600.1Ds
... The Enclosure is 38" W x 14.5" H x 25" D - Tuned @ 32hz ...
Oh Yeah - I'm a 1999 Nissan Sentra GXE 4-Dr
Vehicle: 1999 Nissan Sentra GXE 4-Dr
Head Unit: Alpine CDA-9852
Front Stage: Kicker DS6.5s w/ (4) Power Acoustik NB.4s - Rear Stage: (4) JVC 5-Way 6x9s
Sub Stage: (2) 12" Lanzar OptiDrive 1232s - Custom Ported Enclosure: 6.81cuft Tuned @ 32Hz
Sub Amp: (1) Kicker KX2500.1D - Highs Amp: AutoTek AT-1200.4
Processors: Clarion EQ-746 & Clarion MCD-360
Wiring: Install Bay 1/0 Gauge ( Including Big 3 Upgrade )
Batteries: (3) EverStart Maxx's ( 750 CCA ) 1 In Front & 2 In Back
DJ's Audio Installation
Subs forward port side. Drivers to be specific. Local guy did good numbers with aq 12's and I believe a 3500. Let me see if I can find on local forum. I believe he did 147's but I think his impala was 01 maybe.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Proof?
Anyway to david I run mid 40s with subs and port back because my backseats don't fold down. If your seats fold down I'd suggest sealing off and facing forward. I've heard good things about subs forward and port to the driver side if you seal at the back of the box, but I've never experimented myself.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
  • Who's Online   0 Members, 0 Anonymous, 1426 Guests (See full list)
