ClickBoom Posted November 20, 2011 Report Posted November 20, 2011 Firstly, this is my first post on the SMD forums. Anyway, I just got done with my build in 2000 Chevy S10 Blazer 2 door and have everything except one thing back in: the rear seatbelts! I have them bolted in to the top of the car under the headliner, but cannot for the life of me figure out where they get bolted in to the floor! Has ANYONE taken out/put back in the REAR seatbelts of an TWO door S10 Blazer that knows where they bolt in?!?! Help would be SOO appreciated. Quote Pioneer DEH-P7200HD (2)Rockford Fosgate P3D4-15's AQ-1200D Hifonics 55.4 Polk Audio db components & 6x9's Duralast Gold starter GNB Sprinter 370 accessory
EBW Posted November 20, 2011 Report Posted November 20, 2011 (edited) are you talking about the belt or the lock part? bottom of the strap side are next to the seat, clip bolts to the seat leg itself Edited November 20, 2011 by EBW Quote Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
ClickBoom Posted November 20, 2011 Author Report Posted November 20, 2011 Thanks for the fast reply, I was going INSANE! I'm talking about the end of the belt; the L-shaped bracket. That bolts right to the leg of the seat? Quote Pioneer DEH-P7200HD (2)Rockford Fosgate P3D4-15's AQ-1200D Hifonics 55.4 Polk Audio db components & 6x9's Duralast Gold starter GNB Sprinter 370 accessory
MarioB Posted November 20, 2011 Report Posted November 20, 2011 this might help http://67-72chevytrucks.com/vboard/showthread.php?t=486398 Quote 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
ClickBoom Posted November 20, 2011 Author Report Posted November 20, 2011 this might help http://67-72chevytrucks.com/vboard/showthread.php?t=486398 Hahaha not quite. Those appear to be K5 blazers, which are quite a bit older than the S10's. But thanks man! Quote Pioneer DEH-P7200HD (2)Rockford Fosgate P3D4-15's AQ-1200D Hifonics 55.4 Polk Audio db components & 6x9's Duralast Gold starter GNB Sprinter 370 accessory
EBW Posted November 20, 2011 Report Posted November 20, 2011 (edited) Thanks for the fast reply, I was going INSANE! I'm talking about the end of the belt; the L-shaped bracket. That bolts right to the leg of the seat? the top is near headliner the bottom is at the same level at the seat all behind the plastic, as in the part you sit on, the clip/ lock part is on the leg to the floor Edited November 20, 2011 by EBW Quote Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
ClickBoom Posted November 20, 2011 Author Report Posted November 20, 2011 Thanks for the fast reply, I was going INSANE! I'm talking about the end of the belt; the L-shaped bracket. That bolts right to the leg of the seat? the top is near headliner the bottom is at the same level at the seat, as in the part you sit on, the clip/ lock part is on the leg So the clip is right on the leg? No wonder I couldn't find the bolt hole! Do you have to fold the seats down to access that part of the leg? Quote Pioneer DEH-P7200HD (2)Rockford Fosgate P3D4-15's AQ-1200D Hifonics 55.4 Polk Audio db components & 6x9's Duralast Gold starter GNB Sprinter 370 accessory
EBW Posted November 20, 2011 Report Posted November 20, 2011 http://www.s10forum.com/forum/f136/in-2dr-blazer-how-to-remove-rear-seat-and-seat-belts-381554/ Quote Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
ClickBoom Posted November 20, 2011 Author Report Posted November 20, 2011 http://www.s10forum.com/forum/f136/in-2dr-blazer-how-to-remove-rear-seat-and-seat-belts-381554/ Thanks a million, man. Quote Pioneer DEH-P7200HD (2)Rockford Fosgate P3D4-15's AQ-1200D Hifonics 55.4 Polk Audio db components & 6x9's Duralast Gold starter GNB Sprinter 370 accessory
EBW Posted November 20, 2011 Report Posted November 20, 2011 http://www.s10forum.com/forum/f136/in-2dr-blazer-how-to-remove-rear-seat-and-seat-belts-381554/ Thanks a million, man. no problem good luck! Quote Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
