I was wondering. I've been lookin at a lot of truck builds. And blow through's is what I want. Sometime in the future. Are they considered 4th orders. Or what are they called
Edited by bigmescan
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
I would say most are. Depends on sub oriantation chamber size etc if you build it wrong it will sound like ass. If its done right its brutal
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
It depends on how the enclosure is built. Ones with a sealed chamber with the woofers firing into another chamber that vents into the cabin is a bandpass. Some are ported. Some even have been done as a 6th order which is 2 ported chambers. Your options are pretty big with a blow through. How do you want it to sound?
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
I've just seen many variations. What would be easier in doing a blow thru and just great on music. I'm just asking more as a reference. My balls aren't big enough yet to cut a hole in my cab.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
Budget wise and bang for the buck will be SA 12's or 15's. But this will be down the road. You could call it a low budget blow thru. Around 3k wt's.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
Yeah but a buddy of mine has 4 sa 12's now. I'm trying to get those for 300$. But I have no bass at all right now. So january I should be buying 2 sa 8's for now.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
