XS Power
I just plugged mine in for the first time today and the charging light turned orange (means its charging), then literally 1 minute later the light was green. Is that normal? there's no way my batteries are in that good of shape after the use they get. I just want to make sure the chargers not bad or my batteries are not bad.
so I left it on the charger for a few hours and when I turned the car to ACC (just battery power) to see what they were resting at(stinger volt meter), it was at 13.1 then a fews seconds later 13.0 then 12.9. do I have a bad cell?
A good AGM battery should be in the voltage range of 12.6 to 13.1 volts when fully charged.
So Im sure your batteries are fully charged.
If you had a bad cell your battery would be in the low to high 10s (10.0-10.9volts ruffly). Each cell on most AGM batteries are 2.0-2.3 volts each depending on how you maintain the battery.
