Can a port be too long? I have been going back and forth between WinISD Pro Alpha & Torres' Calculator and on one my enclosures I came up with a 50" long port, but port area & port area range were good. Would there be any problems with that long of a port?
System:
Basically Stock
In process of upgrading
Could you give me the dimensions of what you are trying to do?
Yes, there is a problem - but it may not be depending on your application
A port that long starts to act like a t-line (in this case, ~110-120hz)
Depending on where you have it crossed over at - this may or may not be a problem
Edited by SnowDrifter
Can you post the Torres screenshot?
yea, but I don't have the app thing on my computer where you can save a screen so I'll have to use a camera.
it'll be crossed over at 80hz.
System:
Basically Stock
You will be fine. Although there will be a bit more group delay with a longer port and it will be less efficient than a shorter one
ok well I can't find my SDHC card for my camera but
Net Volume: 2.40 cu-ft.
Port Area Range: 28-23 in sq.
Port Area: 33.75 in sq.
Port Area Per Foot: 14.06 in sq.
Tuning Frequency: 25.99 (I know that seems freakishly low but this was the only tuning that would effectively let me hit 28hz in WinISD & I love my lowwww notes anyways so I figured to just go with it, but I could be wrong)
System:
Basically Stock
How bad do you think it would be?
System:
Basically Stock
Lol dude. Maybe I can convince you otherwise since I made that mistake
I made a box tuned almost exactly to that. (26.1hz) - it hits 20 hz easy - but is a bit lacking on higher notes (55+)
My other box tuned to 30 hits all the way down to 24 hz and plays anything I put through it
I would tune between 29-31 and you will hit it just fine. What sub is this?
