But anyways, anyone got a D4 07 CVR for like 45 or less ? Haha. Also, can you mix like 2 D4s and a D2? I mean..I've heard it's bad and I haven't planned on it, but I'm curious why.
different ohm loads. would be able to give then all equal power.
i don't understand that? wouldn't the amp see all the subs wired together giving a final ohm load and then the power be split between however many speakers are there?
no not if youre using different ohm coils. some subs would get more/less power than the others depending how you wire them
are you saying the the ohm loads affects how much each speaker gets after the power leaves the amp?
Less resistance equals more power flow. The amp itself would be seeing like a 3 ohm load (not calculated, it's just for explanation) but 2 subs would be at say 1 ohm and the other at 2. This means all the would not get equal power causing one to hit mehanical limits before the others
