port is WAY too small you need like 2 maybe even 3 of the ports you have for the right ratio
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
i thought if youre using aero ports its more like 9-13 per cube
Well I wasn't sure if he was using slot or circle.
And I doubt actual aeros will be used.
What should I use then?
aero, pvc pipe, abs pipe.. same difference with out the flare. as long as he has the right I.D. dimensions and displacement correct.
Use whatever is easiest for you. :-)
The flare is part of what makes an aeroport and aeroport. So no, they are not the same.
go with areo if space is a problem or slot if you have the room. both are as efficient to the ear.
Alright, sounds good.
I appreciate the help.
I'll post my new design in a bit if I have time.
