Does ray have a diff user name because i cant find his user name
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
They' ll all be on one amp so
I cant reverse the phase..
Can't you just switch the pos and negative wires?
If i'm wrong, then don't run inverted because you're going to get cancellation. by inverting, you've essentially just reversed the polarity
Edited by 412 CVX
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
I heard that u can switch the wired like u tell me. But i really want this design. If i can t do it inverted then i wont but i still want this design :) thanks , and i still cant reach ray
this design will work fine with a couple modifications.
1 - do a common chamber for all 4 with one big common port, it will work much better.
2 - don't run the outside subs inverted if you can't switch the polarity, which it doesn't sound like you can.
ray will probably tell you something very similar.
More box builds
ANyoneelse?
don't keep asking until you get the answer you want, please.
i'm trying to help you here. if you want that design, fine, you can make it work.
But you NEED to do a couple things if you want it to work right.
first: if you can't reverse the polarity, Don't run the outside subs inverted.
Second: a common chamber for all four subs will work the best, rather than having 3 separate, non-identical chambers.
More box builds
By reversing positive and negative on the two inverted subs that would change the polarity of them. Theres no reason you CAN'T do that.
:trippy:
Edited by BassJunkie
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Ok fine make it all one chamber. Can anyone design this?
All one big box and no inverted subs tunned to 32 hz "" same design tho ""
