If You Want Enclosure Plans Then Here Ya Go!
andym85
whats up bro dont no if u got a chance to do mine yet i need the one port tuned at about 35hx and the other one tuned for burps and only need 75-100in of port thanks
i was going too...but take a look at post #77 in this thread...the only thing different with that box is that it is 1/2" deeper and 1/8"wider than the new dimensions you gave me. so its basically the same exact thing...
i likes me some audio stuff...
Wow thanks!!!
does that program graph the output? does it spec port velocity or anything?
1st  SMD "System of the Month" Feb. 2007
Zapco Studio 500 (2)
Zapco Studio 300X
Zapco Studio 204 (2)
(2) FI 12ssd's w/ copper coils
DLS Iridium Tweeters
DLS UR2.5 MidRange
FI. N.7 Midbass
JL Audio TWK 88
Mechman 370A Elite Alternator
Wow thanks!!!
no...i have tried to use winsd but havent really figured it out...i just try and base it off the manufactures specs...RE says .65cubes for the smallest enclosure tuned to 35...and luckily, your dimensions came out to exactly that after the sub and port displacement
in your opinion , would you perfer the compact ported box over the optimal sealed?
what roll does the woofer location have in the design, i noticed you were specific in the placement of the woofer
Zapco Studio 300X
DLS UR2.5 MidRange
FI. N.7 Midbass
JL Audio TWK 88
oh yeah four CVR 8's kicker zx1000.1 2door sebring coupe. 32wx19dx14t
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
imo it depends on what ur going for...as u are probably aware of. if you are looking for deeper bass that may get louder then i would go ported. if you are looking for more tight/accurate bass (like rock music) but maybe not as loud then sealed. i dont have any personal experience with the re8's but from what i have heard other people say, most seemed to be quite pleased with these subs in a ported enclosure.
as far as the placement of the woofers, i guess that is something that needs to be played around with to find the best spot...i just put them on the opposite side of the port b/c i didnt like the idea of one sub being 'pinned' against the port while the other sub wasnt. i kinda felt like air flow would be maximized in that setup...maybe add a 45 in that corner.
from personal experience with that type of enclosure...with the subs to the passenger side and port on the drivers side...it will sound louder to the driver as compared to the passeneger. i was trying to avoid that by havig a port on each side, but i couldnt make it work.
im really not to technical in my designs. with time and more experience i will probably gain a better understanding of port/woofer placement as well as enclosure size.
if you wanna read up on velocity, then i just found this cool site with a ton of info...it even has a port velocity calculator for flared ports...just not sure what it means yet..lol...gotta read some more..
here is the calc...at the bottom of the page
http://www.subwoofer-builder.com/flare-it.htm
here is the main page on flared ports
http://www.subwoofer-builder.com/port-flares.htm
here is the homepage...looks like lots of good info...time to read...
amatt85,
I really appreciate what you are doing here. Helping out people with box designs. Showing 'em what to do.
We need more people like you this in the hobby.
I can build a box now because I bought a full 4-Piece 18v tool kit for $30.
A drill, jigsaw, sander, and flashlight.
Max dimensions are limitless, whatever will optimize design.
Subwoofer up port back.
Tuning to about 37hz.
Daily.
Subwoofer is One Audiopipe TXX-12B
No bracing.
Here are the specs.
Scroll down to TXX-AP all colors.
There is a typo there it is a Dual 4 ohm coil not 2.
Tried to help as much as I could.
Need anything holler at me.
Would love to play you on moola.
EDIT: Can you tune the box to 37 hertz instead of 43?
Would it make too much of a difference sound level wise?
Thanks.
I need a box design for 2 kicker comp 8's, daily, in a dodge dakota. Would like it tuned to 32-35 hz, measurements are no more than 20 inches high x 28 inches wide x 12 inches deep. Thanks
