If You Want Enclosure Plans Then Here Ya Go!
andym85
it would be an "L" shaped port
L1: 19.5"
L2: 4.75"
that would take u down to about 2.75cubes/sub
i likes me some audio stuff...
on second thought though...if ur doing subs up then i dont think u are gonna have enough height if you port is 4"h..
hallo boys Looking to build a Ported box for my fiat punto03 the sub woofers is massive audio dmx 12"
fs=45.58
qts=0.38
vas=0.599
x-max0.591"
spl{db}=96.74
rms power=2500
max power=5000
impedance=1-1+1-1
this is stats of subwoofer can send me the plans of ported box for this subwoofer!
thangs!!!
umm sence me n u have basicly the same car u think i can do 2 15'' mtx5500 1544's sealed off from the trunk? or how i was thinkin ported but ied prolly take up to much room im tryin to do a sealed box sealed off from the trunk behind the seats n cut around my armrest and port it i guess threw there will that work? or use aeros n port threw the rear 6&1/2 openings? and have em faceing the trunk? lol i want the most trunk space i can get with sealed ima do beauty pannels n ish later tho, ima do sub amp on right side with battery n highs amp on left n prolly fab up somethin for rear componits, what cha think might work best? i had a prefab dual 15 sealed box from audioenhancers faceing trunk with 4500 1544's off a mtx 500d and it was loud as hell with back seat down and hit lows like nothin ive had befor, but with more power and a lilbit more powerful subs u think i can go by mtx's specs like i did on my truck box n do another box kinda like the one i had im kinda gettin out of puttin my rear seat down
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
fs=45.58
qts=0.38
vas=0.599
x-max0.591"
spl{db}=96.74
rms power=2500
max power=5000
impedance=1-1+1-1
thangs!!!
measurements? tuning? sub/port positioning?
you could fit two 15's firing forward if you ported thru the rear deck possibly....might be better off with the typical subs and port back type box...
u think u could design me a box that will sound good im more into sealed boxs but ppl say ported is louder and i want the deep bass from it but they also say sealed boxs help the subs disapate power better than ported cause they can over excursion and fuk up somethin, what u think would work better cause ive always done sealed boxs but i want soemthin louder with deeper sound but ive got it with sealed tho so i dont kno lol
u could try ported, but with two 15's in that trunk u might be better off with a sealed box....if anything you could build the ported one and if u dont like it then put the sealed box back in...
40w x 20h x 30L
Fi Bl 15
30hz, 40hz swappable port
'98 Civic
Subs front Port front inbetween subs
itll prolly need bracing
make it as close to 7.5-8 cubes as possible pleez
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
