If You Want Enclosure Plans Then Here Ya Go!
andym85
40w x 20h x 30L
Fi Bl 15
30hz, 40hz swappable port
'98 Civic
Subs front Port front inbetween subs
itll prolly need bracing
make it as close to 7.5-8 cubes as possible pleez
im not sure if that is gonna work...the lowest tuning i can get with a swappable port is gonna be 35hz...
i likes me some audio stuff...
This is an awsome service man....
35w x 15h x 35L
64hz
89 Honda Crx
Sub facing upwards
port / ports backwards or upwards
Single 18" atomic apx
thanks alot man
just make ur port run the width of the box (33.5") and make it 4"high and you dont even need to add any depth to it..so just a 33.5" x 4" opening....that is gonna give you 8.54cubes tuned at 64hz with 134sq" of port area (or 15.7sq"/cube)...if this is just for burps then that should work...do u want me to draw that up?
ok go wit 35 thatll still be fairly low
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Say bro, im ready to make another enclosure for my boys car...
were gonna be using 2 12'' L7s and the zx1500.1 the dimension are
Width: 30''
Height: 17.5''
Length: 13.5''
tuned to about 34hz-37hz...
Thanks... :rolleyes:
but if you do 35hz, i really dont see any point in doing swappable ports if the other one is just gonna be at 40hz....know what im sayin?
yea i see wut ur sayin. dam i really wanted to try that but i guess this box aint for me.
ok change it to 32 hz and leave the rest of the things the same
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Width: 30''
Height: 17.5''
Length: 13.5''
that isnt gonna be enough room...its only like 1.11cubes/sub....minimum they recommend is 1.75...u might wanna go sealed...
close as i could get it...34hz...
Posted Image
Posted Image
Yes please man that would be great i dont quite grasp what ur saying, also man do u think it would be louder if i used areoports?. i have full acess to 6" areoports... so if that would be best
amatt, wats up man...
well i plan on getting another btl in my truck somehow...
so i might need a design...
i really want my backseat. My dimensions are:
width: 39
Height:30
Depth: 23
Like i said i really want my back seats. But if they have to go thats fine...U can adjust the height and depth to watever but the 39 width is as far as i can go...
o sorry
its for 2 18" BTLs
thanks again..
Lets Go Ski
