If You Want Enclosure Plans Then Here Ya Go!
andym85
Subwoofer----------------18" BL Fully loaded w/o extreme lead
Number-------------------1
Vehical-------------------Ford supercrew
Amp----------------------Kicker ZX1500.1
Type---------------------Daily
Max Hieght--------------22
Max width---------------36
Max depth---------------28
Cubic ft------------------6.5-8
Hertz---------------------31-35
Port all the way to right of box facing up and subwoofer facing up
If you could could you give me excat cut out deminsions, I also will be using 3/4 mdf will i need to double up the front??
Thanks your a life saver
Can you do another one for me? Subs up port back if you can make it work. It can be a little taller and deeper if it needs to be. Thanks.
Subwoofer----------------2x12" type r
Number-------------------2
Vehical-------------------Jeep Grand Cherokee
Amp----------------------2x t3002
Max Hieght--------------16
Max width---------------40
Max depth---------------24
Cubic ft------------------atleat 5.5
Hertz---------------------32-35
hey amatt, i was wondering if you can design a box for me for 4 12" alpine type r's which will be running off a 3000w PT amp. its going to go in the back of a 1999 ford expedition and was wondering what you can come up with. thanks.
3 12" Alpine Type-R's
1 Hifonics 2010d amp
dimensions? tuning? sub/port placement?
i likes me some audio stuff...
well i wasnt sure about the dimensions. i dont compete or anything. but i want it to hit low and sound good, what do u recommend. and i would like subs up, port back towards the rear hatch
well since i have already done it for several people on here i figured i would make a thread dedicated to it....
so if you want some simple box plans, post everything in here.
the following info would be helpful:
-max dimensions
-type of subs
-number of subs
-desired tuning frequency
(i.e. for dialy driving or pure burps)
-type of vehicle
-position of the subs and port
-let me know if u are gonna brace it with 2x4's (or something other than thread rod) so i can figure displacement for that....
i can do a simple google sketchup for it and include dimensions as well...
i do not garuntee any of these plans...if you blow something or mess something up you assume all responsiblity...just a friendly waiver!!
im not gonna charge, but feel free to donate, if u wish, thru paypal :) (paypal payments can be sent to [email protected])
here is a link to the thread about the calculator i made and use...
http://www.stevemeadedesigns.com/board/ind...showtopic=13860
hi there i was wondering if you can make a sketch. 18" kicker solo x. dodge caravan
49x25x27 (l , w, h) its for 1 18'' daily driving and bumping. the cone will face up, and i would like the port on the right side facing up.. i will use 1'' mdf, not braces. i will run about 7000w on this amp
freddy velez
ok AlpineExpo79 im gonna let amatt do all the technical stuff but here is wut i came up wit.
30"w x30"d x23"h
port: 4.5"h x28.5"w x24.75"d
tuned to 32.8 hz
Posted Image
Posted Image
Posted Image
just a rough sketch to give u an idea til he gets around to urs
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
30"w x30"d x23"h
tuned to 32.8 hz
Posted Image
Posted Image
Posted Image
Thanks are those measurements after rhe box is put together.? im. NEw to this box building thing
