NeonGuy937's Ford Focus SE Build Log
why do you keep starting new build logs for the same thing over and over
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Are you doing anything to the suspension? Need more pictures and building details! Don't skimp out (pictures) on how you're going to seal it off, some fiberglass right?
Google it
Ok so some info on the build. Everything is made from birch ply from lowes. Sides rear and top are 1.5" thick double layer 3/4" . Floor has a 2x4 frame with a single layer of 3/4" . Bracing will be done using allthread steel rod. My baffles will be secured with L channels .
My sealed chambers will be glassed at all seams . I used 2x2 in every joint as it's easier to secure when working from the inside of the enclosure .
