NeonGuy937's Ford Focus SE Build Log
Ok , lets start with the basics
Vehicle :2002 Ford Focus SE
Subs : 10 Sony Xplod Gt Series 12"
Intent: Do a 147 or better at 30hz at the headrest .
Now for the Pics :
I did some initial measurements for the entire volume I could use without a complex box. After Wood displacement I had 22 cubic feet of internal volume .
After finding my measurements, i went into Google Sketchup to mock up some ideas.
The Following are 3 usable designs I had come up with :
Failed due to possible motor collisions and cancellation .
This design is useable but only designed for 10" Drivers
This is the design I chose to use for my Build .
This design is made for 10 12" drivers in a 4th order fashion
So before I started building I needed some much needed upgraded wiring .
This is 6 25' spools of 0 gauge CCA Audiopipe Flex Wire .
6 Runs of wire 4 power 2 grounds
This wire is temped down until i get my floor deadened.
Now I added Fuse blocks as i do not want to risk a short
I then upgraded my front battery to a XS D3400
Ok time for some framing and build pics No explanations :
Sorry for not having more pics I am doing all this by myself so i cant stop every 5 seconds ... Ill try to update this as I make more progress
Sony FTW! :shok: Sony's are awesome subs, and RE XXX subs suck sooo you should send that XXX to me. :) But seriously, Sony subs are cheapy low quality stuff but I have seen people use them in big ways. One of the best installers in the world ran Sony equipment for a while. I'll watch, keep the pics coming!
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
