I like your truck man......real clean!!
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
Are you running two different size wires for the Positive and Negative on the RF amp? U really should use same size wire. Besides that it looks like you're learning pretty quick, keep up the effort and you'll continue to get better and better.
1989 Chevy Caprice Classic
350ci V8 High Performance
JVC Arsenal HU
JL XR series components
Infinity Reference 6x9s
Pioneer Premier 4-Channel
Clarion 2-Channel
Rockford Fosgate Series 1 2-Channel
Fusion 2000.1D
MTX Crossover
RF, Knu, Kicker, and Monster wiring
NVX VCW 12in. Sub **Won on here from the Sonic contest!**
*Build log coming soon!*
Starting all over pretty much which the gear listed...lost almost everything I had, including my life. Never take life and what's in it for granted.
yea, im using a bigger wire for the negative
  • 1 month later...
  • 2 months later...
small update, i wanted a new headunit that had 3 sets of rcas and 4 volts, was going to get a single din, but always wanted a touch screen
only problem is my truck is only a 1.5 din, so i just did a conversion
the stereo is a jvc
i didnt have a dremel or something to cut plastic, so i just used a cheap box knife, and blowtorched it until red hot, then just melted the plastic as if it was cutting, after that, i just sand the rough edges
the kit i used was from detailss, it comes with a bracket, some spacers for the headunit, and some plastic strips to cover some spots
here is the link for anyone interested http://www.thedetail...Double_Din.html
this is after some bondo, epoxy, sanded, primed and a coat of white
still needs some work, but school is first
also how does it look with white, or would it be better if i paint it black
coming soon will be a set of t2652s and some deadner for door
  • Who's Online   0 Members, 0 Anonymous, 1682 Guests (See full list)
