electrical system overhaul
Real soon i'm going to be upgrading my whole electrical and I have a few questions.
Anyone have different suggestions on how to write this? I just plan on single runs of 1/0 to everything and just grounding the second battery to the frame not running a ground from battery to battery.
1) is a 270A alt w/ D2700 under hood and aD3100 in the back enough to support 5K RMS?
2) do you just run a 0/1 with a ring terminal on it from the front battery to the rear to connect the batteries
3) my truck already had the big 3, do I just keep it how its wired now with the extra run and stock worrying?
4) what size fuses from
-alt to main bat
- main bat to rear bat
lol
or you can just start hooking shit up together and blow up speakers and your amp
-alt to main bat
your going to need prolly another 3100
AT LEAST 2 runs of power wire from front to back batts.
2 runs of ground from front to back batt.
frame ground on all bats.
2) yes
3)just keep big 3 the way it is. unless its anything less than 1/0
4) no need for fuse to alt
and 2 fuses per run. (one up front and one in the back before the battery.) 300A is a good fuse size.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Would 2 or 3 frame grounds on the battery not be enough?
It's up to him if he wants to put a 300 amp fuse on the alternator + to battery... :shrug:
  • Who's Online   0 Members, 0 Anonymous, 1029 Guests (See full list)
