hhowell1990 Posted December 1, 2011 Report Share Posted December 1, 2011 (edited) Looking at getting a second punch P500-1 for my sub, but before i do I'm going to need to upgrade my alternator, i found one at o'reillys that's a factory replacement for my truck that's 215a, with my current system would it be enough to keep up? Edited December 1, 2011 by hhowell1990 Quote Link to comment Share on other sites More sharing options...
Sid420 Posted December 1, 2011 Report Share Posted December 1, 2011 You have 1000 watts total rms? Quote Link to comment Share on other sites More sharing options...
ineeDBass419 Posted December 1, 2011 Report Share Posted December 1, 2011 You'll be fine with that.but what are the chances of that stock alt actually putting out 215 amps? Quote xbox 360 gamertag-greenrocks420 Not insulting you or anything, but did you just call us "bloody winging fairies" ? Link to comment Share on other sites More sharing options...
jmander11 Posted December 1, 2011 Report Share Posted December 1, 2011 More info on current subs/amps? 1000 rms can be ran off a stock alternator... Quote Link to comment Share on other sites More sharing options...
hhowell1990 Posted December 1, 2011 Author Report Share Posted December 1, 2011 (edited) You have 1000 watts total rms? the 2 punch P500-1's and a p400-4 for my mids and highs so ~1400 You'll be fine with that.but what are the chances of that stock alt actually putting out 215 amps? even if it's less it's probably going to be more than the 105a stock unit that's under the hood of my truck More info on current subs/amps? 1000 rms can be ran off a stock alternator... subs are 2 dc lvl3 15's I'm seeing voltage drops down to 12.5ish when i'm driving at 1500-1700 RPM's, i'm hoping to keep it up above 13.5 Edited December 1, 2011 by hhowell1990 Quote Link to comment Share on other sites More sharing options...
jmander11 Posted December 1, 2011 Report Share Posted December 1, 2011 (edited) Do you have a second battery? With my second battery I see around 13.5ish on full tilt at idle Edited December 1, 2011 by jmander11 Quote Link to comment Share on other sites More sharing options...
hhowell1990 Posted December 1, 2011 Author Report Share Posted December 1, 2011 Do you have a second battery? With my second battery I see around 13.5ish on full tilt at idle diesel, so it's got 2 850cca batteries from factory Quote Link to comment Share on other sites More sharing options...
G-Rad Posted December 1, 2011 Report Share Posted December 1, 2011 (edited) Do the big 3 in 1/0 guage, if it's not done already. After which, you'll see more sufficient power. Clean your ground placements. Sand away paint to ensure better ground. Wouldn't hurt to get a Kinetik, or XS power battery under the hood. Edited December 1, 2011 by G-Rad Quote BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm Link to comment Share on other sites More sharing options...
hhowell1990 Posted December 2, 2011 Author Report Share Posted December 2, 2011 Do the big 3 in 1/0 guage, if it's not done already. After which, you'll see more sufficient power. Clean your ground placements. Sand away paint to ensure better ground. Wouldn't hurt to get a Kinetik, or XS power battery under the hood. Doing the big 3 either tomorrow or sunday weather permitting, hoping that'll make a big difference Quote Link to comment Share on other sites More sharing options...
G-Rad Posted December 2, 2011 Report Share Posted December 2, 2011 You'll notice a difference. Quote BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm Link to comment Share on other sites More sharing options...
