http://www.theretrofitsource.com/index.php
Read. Learn. Enjoy your lights instead of being frsutrated with them.
Unless you've modded headlight housings before, I'd suggest leaving it to a pro, but that's me (and I've taken my housings apart to black them out). Having a nice clean set of housing which have a proper adjustable aim and level, even projectors are difficult.
Glad you're looking at projectors, though. People with HID kits in reflector-based housings should be caned for blinding the rest of us. There's a reason no OEM setups use this method anymore (and only a couple ever tried)
[Rant off]
-Audio
Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R
DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz
Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage
Silver Flute 8" midbass in doors powered by Alpine 3539
Alpine CDA-117 HU
I was asking if it was like Steve's because he showed on his video you put the projector through the old light bulb hole, screw it in, and pretty much done. If it's like that then it should be no problem.
depending on where you live, it looks like those projectors are eurospec because of the cutoff that goes at an angle. i have some on my passat and theyre good but they technicaly are illegal, so if you have a state inspection that checks thatm you might wanna be careful.
I was thinking about doing the headlights in the 2001 olds intrigue I drive, but its my moms car that she said I could have so if I buy it from here then I'll be able to do it, unless I just buy a truck and buy projector lights for it and not retrofit
  • Who's Online   1 Member, 0 Anonymous, 1101 Guests (See full list)
