The "1500" watts amplifier CHALLENGE!!!
fecupe2001
Blablabla... Excuses excuses... We want results! Lol
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
In advance, i have results of:
Hifonics BRZ1200.1 (1200 @ 14.4v)
Digital Designs M1b (1200 @ 11.9v)
Digital Designs M2a (1600 @ 11.9v)
Audiopipe AP1500.1 (1500 @ 14.4v)
I´ll post those results as soon as i can TODAY :)
Ok guys, i´m gonna start posting things over here, i´m having some problems with my phone and i have a few pictures in there so you have to be patient, results so far!!!!
Mechman 270A alternator, 4 runs of 0 gauge, big4 and single Kinetik HC2400 under the hood.
Box: 5.6 cubic feet with 3 6" Aeros tuned at 39 hz
Subs: x2 Digital Designs 2512 D2
Every amplifier on this test has a very nice and clean signal, no distortion AT ALL, also, posting TL scores on the test to show off everything, i want you to take something in mind, i´m only posting the best TL scores i could get with each amplifier, i had to play with a few frequencies until i found the peak with each amp...
First at bat : Audiopipe AP1500.1 wired at 0.5 ohms
Price : about 160$
Class D Mono Amplifier
600 x 1 RMS @ 4 Ohm
950 x 1 RMS @ 2 Ohm
1500 x 1 RMS @ 1 Ohm
1 Ohm load stable
Built In Variable 12 dB/ Octave Crossover
Bass Boost 0-12dB
MOSFET Power Supply 3 Way Protection
Overload protection
Overheat protection
Variable low pass electronic crossover
Variable subsonic filter.
Built-in variable phase shift.
Distortions: <0.2% thd
Signal to noise ratio: 70db
Input level: 0.2-5v
Bass boost frequency: 30-80hz
Low pass filter: 40-180hz
Subsonic filter: 5-50hz
Frequency response: 8-180hz
Dimensions: 7" x 2.5" x 16"
Clamp results :
Voltage drop: 13.6v
44.6 Volts
41.7 Amps
44.6 x 41.7 = 1859 watts
44.6 / 41.7 = 1.06 ohms
Termlab score, sealed on the dash peak @ 42 hz:
I know it looks like shit haha, it´s a video i have on the computer and had to take a picture with my phone since i´m having lots of problems with it and the computer also lol
Second at bat: Hifonics BRZ1200.1 wired at 0.5 ohms (don´t have a picture right now)
Price: About 160$
Power Hadling:
450 Watt x 1 Channel @ 4 Ohm
900 Watt x 1 Channel @ 2 Ohm
1200 Watt x 1 Channel @ 1 Ohm
High Efficiency Super Digital D-Class Technology
4/2/1 Ohm Stable
Bass EQ with 45Hz Bass Boost
Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
Balanced Line Input for MX accessories and Line Drivers
RCA Inputs and Outputs
Built-In System Diagnostics
Illuminated Hifonics Logo
Clamp results:
Voltage drop : 13.9.v
39.2 Volts
35.5 Amps
39.2 x 35.5 = 1391 watts
39.2 / 35.5 = 1.1 ohms
Termlab score, sealed on the dash at 42 hz:
I don´t know about you guys, but those 160$ for an Audiopipe it´s just a crazy bang for the buck, i could get 1800 watts from that amplifier without any clipping, it´s a little bit power hunger IMO but damn, i felt in love of that amplifier right away lol, i don´t know much about the amount of daily abuse it can take though...
My opinions about the hifonics BRZ1200.1 , it definitely can give you rated power if you can keep your voltage drops at minimun, it´s no way near as powerful as the Audiopipe1500.1 , but i can tell you this, definitely not a power hunger , and also, i used a pair of bxi2610D´s for almost 2 years with GREAT success, so , the hifonics quality and durability is without a doubt an A+
BXI and the BRZ series are WAY different. i wouldnt compare the BRZ1200 to the BXI equivalent. although ive never seen clamp tests of a BXI series, i have always heard that BXI/HFI doesnt do rated while the BRZ does. (i have done NO testing on this what so ever, so this is just opinion and possibly a wrong one at that).
I'd hold off on saying the quality of hifonics is A+ until you test the BXI series.
I personally own the BRZ1200, so im in heaven with these tests. I really want to say thanks for taking your time, and testing some of the budget amps :]
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Third at bat: Digital Designs M1b
Here you have some pictures comparing the M1b against the M2a :)
Input Sensitivity 8V - 0.2V
Variable High Pass Filter
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
Variable Sub-sonic Filter 10Hz - 50Hz @ 24dB/Oct
Variable Bass Boost
Tested Voltage 12v -14v
Tested THD ≥1%
Damping Factor
Signal to Noise >100dB
Channels 1
Cont Power at 1 ohm 1150W x 1 @ 12v
Cont Power at 2 ohm
Cont Power at 4 ohm
Bridged
Dynamic Power 2500 x 1
Efficiency thru Output 80%
Dimensions - mm 350mm L x 175mm W x 51mm H
Dimensions - inches 13-3/8 L x 6-7/8 W x 2-1/8 H....15-1/8 L w/ mounting feet
Shipping Weight 11 lbs, 5 kg
Clamp results :
Voltage drop: 13.5v
49.1 Volts
45 Amps
49.1 x 45 = 2209 watts BOOM!!!!
49.1 / 45 = 1.08 ohms
Termlab score, sealed on the dash @ 42 hz :
I guess my box isn´t as efficient as i thought, my 1200 watts amplifier it´s actually a 2400 watts amplifier hahaha, i honestly doubted my clamp results so i re-did everything and had the exact same results, so you can imagine what´s about to happen now , testing the M2a :peepwall:
Fourth at bat: The mighty Digital Designs M2a
Variable High Pass Filter n/a
Variable Bass Boost
Tested THD ≥1%
Damping Factor
Channels 1
Cont Power at 1 ohm 1650W x 1 @ 12v
Cont Power at 2 ohm
Cont Power at 4 ohm
Bridged
Dynamic Power 3500 x 1
Dimensions - mm 500mm L x 175mm W x 51mm H
Dimensions - inches 19-3/4 L x 6-7/8 W x 2-1/8 H....21-1/8 L w/ mounting feet
Shipping Weight 15 pounds, 6.8 kg
Clamp results:
Voltage drop : 13.2v
52.1 volts
48.1 amps
52.1 x 48.1 = 2506 watts FUCK YEAH!!
52.1 / 48.1 = 1.08
Termlab score, sealed on the dash at 42 hz :
I did clamp the bxi2608D i had and then, the 2610D and both amplifiers were the exact same amp, one from 2008 and the other from 2010 with different colors, both did rated power, back then, the 2608D did something like 800 watts @ 3.5 ohms after rise and the 2610D did 1900 watts around 2 ohms after rise, don´t remember the exact numbers right now, but NEVER NEVER EVER compare the BXI series with the piece of crap HFI line, the brutus line it´s a great bang for the buck amp that does rated power if you can keep a nice electrical to back it up, just like the BRZ line does.
Congrats on having a brz1200.1 , that´s one kick ass amplifier if you ask me, 1400 watts for 160$ with a great durability?? that´s a nice choice if you ask me, and thanks for chiming in the topic, my pleasure also to post this things up for you guys :D
I forgot to mention, there´s a bxi1610D on this test hehe, so it´s gonna be fun testing that thing out, also, on the next "2000-2500 watts amplifier challenge" there´s a BRZ2400.1 offered for a test :)
i know, ive been glued to this thread when you said BXI and BRZ, it would be really great if you could get your hands on a HFI amp so you could completely cover hifonics as a company and be able to give them a real rating.
although with the BRZ doing rated, theres really no reason to grab a HFI.
and im really sorry for comparing BXI to HFI, i did say i could be wrong lol. i wont do it again :P
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
haha it´s cool mate, just wanted to get that clearify lol, i think i could get my hands on a HFI 1000.1 but that´s about it, but i honestly think it´s a waste of time, i owned an hfi2500D for a few weeks and ditched that thing right away, it wasn´t no way near as loud as my bxi2610D was :woot:
