was thinking of gettin this radio but not sure if it will handle 2 12 re sex's and brutus amp... meaning is this radio made for hooking up a systems to it...http://www.lightinthebox.com/7-Inch-Motorized-Touchscreen-2-Din-Car-DVD-Player---RDS---Support-iPod---Steering-Wheel-Contrl---BT---TV-SZC6420-_p184676.html
it does have a subwoofer output if that's what your asking?
there is some VERY hard headed people out there. Anyone who says a DD-1 isnt necessary is also saying an O-scope isnt necessary. Anyone who says an O-scope IN THE MINIMUM isnt necessary, is a noob. Forget the DD-1 for a minute, any reputable installer will at LEAST use an O-scope. Those guys in that thread are clowns. Hard headed clowns.
Headunit - Pioneer AVH-P4250 DVD
4 - infinity reference 6.5
a pair of infinity reference tweeters
1 - AudioQue AQ-120.4 amplifier for mids & highs
1 - AudioQue AQ-2200D Monoblock
1 - AudioQue HDC315
KitAudio kerf ported Enclosure
4 - Stinger pro series signal wires
20ft Stinger 1/0Ga power & Ground wires
Big Three Upgrade
1 - Kinetik HC1800 (Not Here yet . .Still Saving up for one)
It says it has sub output, but doesn't say how many pre outputs it has. So i would assume that if you want to put a amp to it that it would only be for subs and you would have to run mids and highs off the deck. And it doesn't say what the preamp output is ex. 4v preamp. Without much info on this 2din i would say no unless you just want to hook up the subs and thats it.
. nvm
Edited by bass_stalker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Specification
System
External Memory Up to 32GB
Detachable Panel No
Features Built-in Bluetooth, GPS, Steering wheel Control, TV, Radio, iPod, RDS, Touch Screen
Display
Display Mode 16:9
Screen Size 7 inch
Touch Screen Yes
Screen Resolution 480 x 234
Display Type LCD-Analog Screen
Brightness Control Yes
OSD Languages English, French, German, Italian, Russian, Arabic, Chinese
Radio
Radio tuner AM, FM
Station preset qty 30
Support RDS Yes
Radio response bandwidth AM: 520 KHz-1700 KHz;FM: 87 MHz-110 MHz
DVD
Video Output System NTSC, PAL
Media type CD, DVD-R/RW, Mp3, VCD, WMA, JPEG, Mp4, DVD
Signal-To-Noise Ratio 85 dB
TV tuner
Digital TV or Analog TV Analog TV tuner
TV antenna Comes With A Built-In TV Tuner - (TV Antenna Not Included. Option To Purchase Available During Check-Out).
Amplifier
Amplifier max output power / channel qty 45 Watts x 4
EQ mode Classic, Rock, Pop, Jazz
Remote Control
Remote control Infrared
Bluetooth
Version V2.0,support AD2P(Bluetooth Stereo Music),can play stereo music through Bluetooth
Built-in microphone Yes
Received Call Yes
Dialled Call Yes
Missed Call Yes
Interface
A/V Input 2 Channel
A/V Output 4 Channel
Connector Type 1 x A/V IN, 1 x A/V OUT, 1 x BRAKE CHECK, 1 x REARCAMERA, 1 x IPOD, 1 x TV ANTENNA, 1 x POWER, 1 x AUX-IN, 1 x USB, 1 x GPS ANTENNA
Card Port SD Port, USB Port
Support iPod Yes
Direct Connection Cable for Ipod Included Yes
Additional Features
Portable HDD Compatible No
Built-in Speaker Yes
CDC(CD Charger) No
Subwoofer Output Yes
Motorized slide-down Face Yes
Anti-Shock Yes
General
Style Universal In-Dash
Type 2 Din
Color Black
Dimensions / WxDxH(mm) 180×175×100
Operation temperature(℃) —20℃~70℃
Storage temperature(℃) —25℃~75℃
Net Weight(kg) 3.4
Warranty 1 year
What's in the box
1 x DVD host
1 x Remote control
1 x User's manual
1 x Cable set
1 x Front frame
1 x iPod cable
1 x USB cable
1 x Mounting hardware
I would say it could be good as an inexpensive dvd receiver but when you start going into adding more speakers and subs i wouldn't go for it... my opinion though
edit: Entertainment: This 2-DIN Car DVD player comes with a region-free DVD player that plays DVD's from any country, as well as all CD and VCD formats. In addition, this car media system also plays music from your iPod or MP4 player, as well as run audio and video files stored on SD cards or USB flash drives.
Thats good if you are going to be overseas as in being in the military and station somewhere. I have dvds from the UK that are different and cant play on my dvd players unless they play the right region code.
Edited by KenC210
  • Who's Online   0 Members, 0 Anonymous, 1107 Guests (See full list)
