monsta409 Posted December 5, 2011 Report Share Posted December 5, 2011 was thinking of gettin this radio but not sure if it will handle 2 12 re sex's and brutus amp... meaning is this radio made for hooking up a systems to it...http://www.lightinthebox.com/7-Inch-Motorized-Touchscreen-2-Din-Car-DVD-Player---RDS---Support-iPod---Steering-Wheel-Contrl---BT---TV-SZC6420-_p184676.html Quote Link to comment Share on other sites More sharing options...
Trigg Posted December 5, 2011 Report Share Posted December 5, 2011 it does have a subwoofer output if that's what your asking? Quote there is some VERY hard headed people out there. Anyone who says a DD-1 isnt necessary is also saying an O-scope isnt necessary. Anyone who says an O-scope IN THE MINIMUM isnt necessary, is a noob. Forget the DD-1 for a minute, any reputable installer will at LEAST use an O-scope. Those guys in that thread are clowns. Hard headed clowns. Link to comment Share on other sites More sharing options...
CaptainPooPyPantz Posted December 5, 2011 Report Share Posted December 5, 2011 yep will work Quote Headunit - Pioneer AVH-P4250 DVD 4 - infinity reference 6.5 a pair of infinity reference tweeters 1 - AudioQue AQ-120.4 amplifier for mids & highs 1 - AudioQue AQ-2200D Monoblock 1 - AudioQue HDC315 KitAudio kerf ported Enclosure 4 - Stinger pro series signal wires 20ft Stinger 1/0Ga power & Ground wires Big Three Upgrade 1 - Kinetik HC1800 (Not Here yet . .Still Saving up for one) Link to comment Share on other sites More sharing options...
herbykw Posted December 5, 2011 Report Share Posted December 5, 2011 wow, unless i m blind and not seeing it, that site doesnt tell you a brand name, or very much info on the deck. Quote 06 300C 5.7 Hemi K&N CAI JVC KW-AVX640 6.1" DVD DC Audio 3.5k 6 DC Audio 8"s 6 cubes 8" aero port at 32hrtz http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834 Link to comment Share on other sites More sharing options...
KenC210 Posted December 5, 2011 Report Share Posted December 5, 2011 It says it has sub output, but doesn't say how many pre outputs it has. So i would assume that if you want to put a amp to it that it would only be for subs and you would have to run mids and highs off the deck. And it doesn't say what the preamp output is ex. 4v preamp. Without much info on this 2din i would say no unless you just want to hook up the subs and thats it. Quote Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
bass_stalker Posted December 5, 2011 Report Share Posted December 5, 2011 (edited) . nvm Edited December 5, 2011 by bass_stalker Quote JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow. Link to comment Share on other sites More sharing options...
monsta409 Posted December 5, 2011 Author Report Share Posted December 5, 2011 was mainly worried about it being a oem factory type radio wasent sure if it would go well with the set-up.... and thanks guys for the fast replys Quote Link to comment Share on other sites More sharing options...
monsta409 Posted December 5, 2011 Author Report Share Posted December 5, 2011 Specification System External Memory Up to 32GB Detachable Panel No Features Built-in Bluetooth, GPS, Steering wheel Control, TV, Radio, iPod, RDS, Touch Screen Display Display Mode 16:9 Screen Size 7 inch Touch Screen Yes Screen Resolution 480 x 234 Display Type LCD-Analog Screen Brightness Control Yes OSD Languages English, French, German, Italian, Russian, Arabic, Chinese Radio Radio tuner AM, FM Station preset qty 30 Support RDS Yes Radio response bandwidth AM: 520 KHz-1700 KHz;FM: 87 MHz-110 MHz DVD Video Output System NTSC, PAL Media type CD, DVD-R/RW, Mp3, VCD, WMA, JPEG, Mp4, DVD Signal-To-Noise Ratio 85 dB TV tuner Digital TV or Analog TV Analog TV tuner TV antenna Comes With A Built-In TV Tuner - (TV Antenna Not Included. Option To Purchase Available During Check-Out). Amplifier Amplifier max output power / channel qty 45 Watts x 4 EQ mode Classic, Rock, Pop, Jazz Remote Control Remote control Infrared Bluetooth Version V2.0,support AD2P(Bluetooth Stereo Music),can play stereo music through Bluetooth Built-in microphone Yes Received Call Yes Dialled Call Yes Missed Call Yes Interface A/V Input 2 Channel A/V Output 4 Channel Connector Type 1 x A/V IN, 1 x A/V OUT, 1 x BRAKE CHECK, 1 x REARCAMERA, 1 x IPOD, 1 x TV ANTENNA, 1 x POWER, 1 x AUX-IN, 1 x USB, 1 x GPS ANTENNA Card Port SD Port, USB Port Support iPod Yes Direct Connection Cable for Ipod Included Yes Additional Features Portable HDD Compatible No Built-in Speaker Yes CDC(CD Charger) No Subwoofer Output Yes Motorized slide-down Face Yes Anti-Shock Yes General Style Universal In-Dash Type 2 Din Color Black Dimensions / WxDxH(mm) 180×175×100 Operation temperature(℃) —20℃~70℃ Storage temperature(℃) —25℃~75℃ Net Weight(kg) 3.4 Warranty 1 year What's in the box 1 x DVD host 1 x Remote control 1 x User's manual 1 x Cable set 1 x Front frame 1 x iPod cable 1 x USB cable 1 x Mounting hardware Quote Link to comment Share on other sites More sharing options...
KenC210 Posted December 5, 2011 Report Share Posted December 5, 2011 (edited) I would say it could be good as an inexpensive dvd receiver but when you start going into adding more speakers and subs i wouldn't go for it... my opinion though edit: Entertainment: This 2-DIN Car DVD player comes with a region-free DVD player that plays DVD's from any country, as well as all CD and VCD formats. In addition, this car media system also plays music from your iPod or MP4 player, as well as run audio and video files stored on SD cards or USB flash drives. Thats good if you are going to be overseas as in being in the military and station somewhere. I have dvds from the UK that are different and cant play on my dvd players unless they play the right region code. Edited December 5, 2011 by KenC210 Quote Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
monsta409 Posted December 5, 2011 Author Report Share Posted December 5, 2011 My wife was buying for me for x-MAS... So iguess ill have to search for another kind.. Really wanted a 2din but iknow shes not gonna pay more than 200 for one... Quote Link to comment Share on other sites More sharing options...
