SKY HIGH DC MONSTER GMC SHORT VID LINKED TO FLEXING SHOP WALL
Great, thanks for the info J! Yeah when all is said and done, I'll probably be towing a travel trailer so I wanna make sure I can have power enough to tow. Be a shame to have a 460L motor and not be able to use it to it's ability! Wish it was a diesel though!
if your concern is towing do not do blocks at all in the back and if you do at least do trailing arm to help you with some of the axle wrap. i have a 2" block in the back and i can see that the axle has moved (already) backwards so i need to loosen everything up and straighten it then retighten lol sounds like fun!
So a trailing arm will stop the axel wrap? I can't seem to find on online, is that something I have to have made? I'm looking. You know what, I'll look more and ask on my Ford Forum. I don't wanna take up too much here asking questions for me. I got the jest of it. I'd love to get her up to 8" or more! We'll see what I can put together! Thanks man!
truck looks fucking beast man, any audible difference with the switch in amps?
thank you very much! and i dont know yet...there is not any subs in my truck and the old subs are not going back in so ill never know.
I know for sure he doesn't even have all the old subs!! :peepwall:
Scooter, you might not be able to use the factory drive shaft since it is a 2 piece unit with a middle bearing (at least that is what is on my 86).
formerly known as Blue86f150
this sux camel dicks
scooter: ya all a trailing armm does is hold the axle where it is horizontally...i need them back. and they should make some for it.
blue: if he does have a 2 piece then ya you are right for sure. or lower the part with the carrier bearing to make it a straight line once the rear lift is done.
Contact us for the best quality cables and accessories with the fastest shipping in the industry
EMAIL: [email protected]<script data-cfhash='f9e31' type="text/javascript"> /* */</script>
LIKE US ON FB: https://www.facebook.com/SkyHighCarAudio
ADD ME ON FB: https://www.facebook.com/jon.rabe.1
MONSTER SKY HIGH/DC GMC: http://www.stevemeadedesigns.com/board/topic/127057-sky-high-monster-gmc-walk-through-12-lvl-5-15s-6-9ks-trim-panels-and-wiring-p-90/
Thanks guys - Ok I have no idea on the axle and it's at home not here at work with me. But these are basically what you're talking about right? Traction Bars. Then I need the mounting kit.
I was reading on the forum though, that not having the blocks makes for a worse ride which is not good either. What about putting bags in there instead? Don't flame me, I'm not sure so I figured I'd ask. Even with the bags though I'd have to have the bars right? I only need one set for the rear, or should I get another one for the front too?
What did it cost for your axle John? It's an 8ft bed and crew cab if that makes any difference.
i am not sure on the bag situation cause ive never done it honestly. but i do know that would help your ride and im sure youd still need the traction bars. and yes those are correct.
the driveline cost me 500 its made out of schedule 103 4" steel and i got all new everything basically so thats cheap i think so what i got. that was a bayshore here in reno. they did an awesome job and had a quick ass turn around time.
and i would assume your front end already has them (i dont know for sure) most fords do...and my axle in front which came from a 98 ford 350 with dana 60 has mounts for the linkage but like i said idk if yours has it.
scooter: i would definitely regear the axles, i'm not sure if you have a diesel or gas motor. which will play a role on how low you should go.
if its a gas motor i'd do 5.13s or 5.38's,if diesel, go for 4.56's. as for blocks in the rear, i wouldnt do it. i've seen blocks crack or even get spit out.
i've had a 2" block decide it didnt want to be part of my truck anymore. it wasn't fun, of course i was out beating the shit out of it when i spit it out.
if you do add a block, make sure its steel, not aluminium or those cheap as kits from vatozone.
this has me lol, you're are going need a forklift and a pallet if that wall ever comes out.
after seeing this, my truck will be a midget next to yours.
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
badasschevy: the wall cant come out without a chain saw lol so its never coming out...maybe someday the baffles will be replaced but thats about it lol
and ur trucks big too lol im sure itll be fine! someday we will see.
cradnis: that shit made me laugh that you thought of it lol i wish my truck could drive on cars...maybe someday we will see if it can once i get the front driveshaft situation figured out lol i really want to try
My dad has air bags on his v12. We haul 2 four wheelers, my dirt bike, a 21 ft camp trailer and like 100 gallons of water and the truck doesn't squat at all. Without a load tho it rides rough as hell so you have to be sure to let the air out.
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
