Just wondering if you experienced guys know any tips or tricks to make it easier mounting subs in a wall. I don't want to drop anything, and I am by myself. Also, it doesn't seem sensible to use the normal screws when mounting vertical...wouldn't the weight of a serious woofer just pull the screws out of the wall? What would you guys recomend using?
T Nuts and security bolts/screws
When you start. use a couple of studs to get the sub in place. Long flat head screwdrive / prybar of some sort, heck even a tire iron since you are solo you may need the extra leverage. What type of subs are you installing ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
LOL...puttin in some FI BTL's...haven't ordered the recones, yet, but I will either be sticking with 15's or going up to 18's if I can find the room.
