Voltmeter reading
I have 4 batteries in car. 1 under hood , 3 in trunk. My question is if i use a cig lighter voltage meter will i get just the voltage of front battery or average of all 4 batteries? is there a good low cost voltmeter i can use to mount in dash and what would i connect it to?
thanks for all your help
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
i have 4 batteries to in my car and i've got a volt meter that plugs into the cig lighter, seems accurate enough to me... and it won't read just the front battery. Total voltage
"This next song goes out to everyone within a 5 block radius"
sweet so i can get a nice voltmeter to mount somewher in dash but i cant find a descent spot to flush mount
i got a 02 monte ss and dont know what kind to get and not sure how mushc space i actually have to put one
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
i have one more odd question but , say the battery under hood would go bad would the other batteries start car and run it .. i have always just wondered what would happen if it ever happened
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
Ideally, you want a voltmeter connected to the amps + and - because the largest voltage drop is at the amp (inside on the transformer), then rear batts if there are rear batts, then front batt, then the rest of the cars electronics.
a stinger volt meter is the most common seen on this site, its about $20 and is a simple 3 wire hookup
ok i have 3 rf amps and 3 batteries in spare tire well and 1 under hood..so technically i should have7 meters?
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
i listed order of priority when connecting one meter. you only need 1 and its almost always going to be connected to the sub amp since that amp will be drawing the most current.
if you have your bd1500s sync'd then use the master amp
thanks for all the info ...thanks for all ur hard work on the songs as well ..even tho i cant get them anymore lol..thanks again
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
  • Who's Online   0 Members, 0 Anonymous, 1852 Guests (See full list)
