Sony 5-1/4" Square Frame Neodymium Woofers These Sony neodymium woofers feature attractive, high quality treated paper cones, high-excursion flat spiders, extended pole pieces for improved bass response and are Magnetically shielded
Specifications:
*Power handling: 20 watts RMS/40 watts max
*VCdia: 1"
*Le: 1.52 mH
*Impedance: 8 ohms
*Re: 7.71 ohms
*Frequency response: 80-6,000 Hz
*Fs: 81 Hz
*SPL: 85.3 dB 1W/1m
*Vas: 0.16 cu. ft.
*Qms: 7.81
*Qes: 1.10
*Qts: 0.96
*Xmax: 3 mm
*Dimensions: Outside Diameter: 6 7/16", 5-1/ 4" across flats, Cutout Diameter: 4-7/8", Depth: 2-1/2".
New never mounted, I tested 2 of them to see what they sound like..I wasn't dissappointed once I got the rear wave seperated from the front..they sound pretty good with 50rms on a pair crossed over at 120hz...I plan on using a hand full of these in my car
I'm intending on selling them in sets of 4 for $25obo shipped to your door...pm for quotes on more than 4 send me a pm or email: [email protected] ....email is the best way to contact me
Edited by Rogers
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
hey man if i have any extra cash after i finish up my xmas shopping i would definitely take a set of four. Would those keep with 4 selenium 6s 2 cadence 8s and 4 super tweeters?
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
