hey guys i have a ford f150. its a 4.2 v6
so there are not many performance options out there for me.
standard gears are 3.55
i have the truck lifted with 33'' inch tires on it. plus the shit load of soundsystem equipment.
its lacking in low end power. i dont normally speed or drive over 80 on the interstate.
so what im asking is.
what would give me a good boost without absolutely destroying mpg. and id rather not be doing 3500 rpm at 70 mph
i thinking that larger gears would help my mpg making it easier to move the tires.
but would a 3.9 or 4.10 gear be better.
i can also go to about a 4.56 gear. there are some in between as well.
thanks guys.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
If youve got a taller tire the effect of a rear gear change isnt as big of a deal on your MPG because your going back closer to a stock ratio.
I ran a 29" tire on my camaro with 4.56s and got better mpg than the stock 26" tire and 3.42 gearing.
Find a ford forum and see what guys are doing gear wise for 33s to get a little of the low end back. Im sure a 3.90 with the autio would be plenty
lol
or you can just start hooking shit up together and blow up speakers and your amp
yeah im leaning towards the 3.90
but the 4.2 only has 150 to 200 ftlbs of torque so maybe the 4.10 would work better. because i will be having 2 xls and a wall in my truck daily. as well as any other stuff that goes in the bed.
I'm assuming you have a model that can be tuned with a tuner? if i recall right you can alter the shift points and that might help you with mileage and what not, just besure to save your stock tune so you can revert if you need to
I would say 410s would be a good choice but you would get higher rpms while cruising on interstate and such I bielive..
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
If you run a higher numeric ratio i.e. 4.10:1 vs 3.55 then you will have less of a tendency to ruin your rear end while you are running big tires. It will take the extra load off associated with running a larger diameter tire which intern lowers the numeric ratio. The bearings are what will typically fail, and the 4.2 doesn't exactly have the stoutest rear end. . Whatever you can get with a higher ratio for your rear end housing will help with reliability. I rebuilt the rear end on a 4.2 with big tires that only had 20k on it. Do the math and see what ratio will bring you back to stock driveshaft revolution speed per mph with your 33's. The 4.2 pistons have a long stroke so your not gonna want to spin alot of rpm's as long stroke=lower rpm capability due to a higher piston speed, so in short your engine's most efficient rpm will likely be low. I can't tell you what that is. x senior master ford driveline specialist
yeah i know rpms will get higher at interstate speeds. but i cant afford a tuner right now.
but regearing is a cheaper option without changing the computer and screwing everything up
yeah when i regear im going to replace the bearings. basically rebuild the whole thing. and im sure the rear end on my truck is going to get worse over time. ive only had the tires on for a year or so. but i baby the truck. i cant afford to dog it. i dont go mudding anymore. just trails.
  • Who's Online   0 Members, 0 Anonymous, 1295 Guests (See full list)
