why do I peak so high?
I have 3 18's and 9k of power! my box is 15 cu ft after all displacements tuned between 27 and 28hz 12in of port per cu ft. my peak frequency is 43hz. why do I peak so high when I'm tuned so low?
the 28hz port is removable, when I take it out, my box is 15.5 cu ft tuned to 43hz 16in of port per cu ft. still peaks at 43hz but 1db quieter. shouldn't it be louder since its tuned higher and more port area???
I can get up to a 149.6 on a term-lab. should I be hitting better numbers with my setup? should I build a better box???? any tips on how I can build a better box? (enclosure volume, port area, tuning)
equipment is 3 dc xl 18's on a dc 9k, 2 330amp singer alts, 3 kinetik hc2400s, 2 hc3800s,with 6 runs of pos and 4 runs of neg 1/0 gauge
  • Who's Online   1 Member, 0 Anonymous, 1144 Guests (See full list)
