yes you can have too big of an alt. my alt i got was too big and it wouldnt fit in place of my stock alt. i know thats not what you were asking, but it is literally what you asked lol.
but just curious, did you properly set your gains? if you didnt set your gains properly, that could be the problem. what size amp is it?
Alpine CDA-9886Hertz Mille 3 ways active
Hertz SPL Show 8's
2 Audison Voce Quattro's2 DC Audio M2 Level 5 12'sDC Audio 12.0KKnuKonceptz Wiring4 XS Power D3100'sDC Power 390XPSecond Skin Damplifier Pro and Dynamat Xtreme
The gains are all the way down since I have a bass boost knob hooked up to the amp all the way turned up. I have a 1500 watt hifonics amp. I'm pulling 1000 watts with my subs( and Im pulling 400 watts from my mids and highs but that amp isnt hooked up because of the voltage drop) I'm going to be getting a fi bl 10 in the next couple of weeks so I'm going to be pulling 1500 watt for my sub then. So I will be pull 1900 watts max in the next couple of weeks
dont use the bass boost knob whatsoever, and tune your gains with an oscilloscope or a dd-1 (if you have it). your amp settings are, at least the way i see it, fucked up.
yep. and that alone can cause you to have bad voltage drop and for your shit to sound messed up. the bass boost being all the way up could also be the 1 thing making it sound bad (if its a bad enough boost)... tune properly, and then see how it sounds and go from there. not sure with your vehicle, but my car could handle a 1500 watt amp no problem on stock electrical.
Hertz SPL Show 8's
So you have an extra 120 amps out of your stock electrical?? Or are you running Boss Amps?? LOL
2007 Pacifica
No alt wont always output the full amps example 200 amp alt. NOT 200 amps all the time thats just the max
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
If this was me, I would contact mechman and order the biggest alt I could fit with a voltage boost module. That way for future upgrades you are set.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Same as you i have a 2000 watt brutis hifonics on all stock eletric and the only thing it does is dim my head lights but i also have a v8
  • Who's Online   0 Members, 0 Anonymous, 3240 Guests (See full list)
